First try initialize and format (make a backup of your most important files first) your disks from BH. Internal HDD you can format as you like, I think in ext3, or ext4, external better in fat32 (or ntfs for support files bigger 2GB), to use it in windows USB too. Then you can mount them. If you need manual mount in fstab by UUID, execute a command in terminal (I use putty)ls -la /dev/disk/by-uuid to see it.I have the similar problem. My internal hdd and external disc 2TB dont mount at all or sometimes I am able to mount them (only hdd) manually.
