Jens F. Gabe
I have vu+ duo2 and the latest version of VTI. I have tried to configure autotimer and refreshepg so that I can fetch epg. But it does not work, and after a running the VU closes and reopens in 3D. My configuration is as texted below. Would somebody please help me.
The configuration for epg is as follows
Refresh automatically yes
Show in extension menu no
Show popup when refresh starts and ends yes
RefreshEPGusing main picture
Wake up from deep standby forEPGrefresh yes
Duration to stay on service (seconds) 90
EPGrefresh auto-start ealier 8,35
EPGrefresh auto-refresh later 8.40
Delay if not in standby 10
Force scan even if receiver is in use yes
Shutdown after refresh yes
Saveepgto file afterepg-refresh yes
Inherit Service frolmautotimeryes,
Runautotimerafter refresh yes
The autotimer is configurated thus:
Activated yes
Description epg
Match title iirc
Service type title or short description match
Service strictness case-insensitive search
Timer type record
Override found with alternative service no
Only match during timespan connect
Begin timespan 8.30
End time span 8,45
Restrict to events on certain days disconnect
Custom offset disconnect,
Set maximum duration disconnect
After film go to standby
Execute "after event" during timespan disconnect
Record maximum of x times 0
Require description to be unique no
Use custom location yes
Custom location /media/hdd/movie/
Tag none
Activated yes
Description epg
Match title iirc
Timer type record
Begin timespan 8.30
End time span 8,45
Tag none
