When viewing Service Press on remote first EPG then Yellow
View All 7day programs select desired program and press Green on remote.
A new Timer will be added for you.
Later you can edit options by pressing Menu/Timers.
Regards.
P.S
To download EPG data Press Blue/Red select from the List.
I'm working on such a plugin for that provider.
It is on betatesting and hopefully soon on the Addon Server (some snapshots here: raistplugin.altervista.org).
Just install the Autotimer from the software manager. It works fine in my Duo.
First Setup=>System=>Customize Set to ExpertCan't seem to find it? Where is it in the Addons Download Manager??
I'm sorry, it will work with italian provider.Dear dalraist,
Please confirm if it can be used with CSAT and all other french channels?
Regards
but you mean this ?
AUTO TIMER
1.Main Menu >>Plugins >> RED Button (Manage extensions) >>Electronic Program Guide>>Auto Timer>>
OK>>red >>red>> Green button Only extensions
