AVERTV VOLAR HD A835
I had the same problem with an A867 device. Quoting your log:
usb 1-1: dvb_usb_af9035: prechip_version=00 chip_version=03 chip_type=3802
usb 1-1: dvb_usb_v2: found a 'AVerMedia HD Volar (A867)' in cold state
usb 1-1: dvb_usb_v2: downloading firmware from file 'dvb-usb-af9035-02.fw'
usb 1-1: dvb_usb_af9035: firmware version=12.13.15.0
usb 1-1: dvb_usb_v2: found a 'AVerMedia HD Volar (A867)' in warm state
usb 1-1: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
DVB: registering new adapter (AVerMedia HD Volar (A867))
DVB: Unable to find symbol af9033_attach()
It says that the kernel module af9033 is missing (as well as mxl5007t). I think that there are some problems with the driver dependencies in the repository.
You can fix it connecting to the shell with telnet or ssh and typing:
opkg update
opkg install kernel-module-af9033
opkg install kernel-module-mxl5007t
(then remove and insert again the tuner and restart gui)
It should work.
From your new logfile
it913x: Chip Version=02 Chip Type=9135
it913x: Dual mode=0 Tuner Type=38it913x: Unknown tuner ID applying default 0x60
usb 4-1: dvb_usb_v2: found a 'Avermedia A835B(2835)' in cold state
usb 4-1: dvb_usb_v2: downloading firmware from file 'dvb-usb-it9135-02.fw'
it913x: FRM Starting Firmware Download
it913x: FRM Firmware Download Completed - Resetting Deviceit913x: Chip Version=02 Chip Type=9135
it913x: Firmware Version 52887808<6>usb 4-1: dvb_usb_v2: found a 'Avermedia A835B(2835)' in warm state
usb 4-1: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
DVB: registering new adapter (Avermedia A835B(2835))
DVB: Unable to find symbol it913x_fe_attach()
It's also missing the kernel module it913x_fe, try with
opkg update
opkg install kernel-module-it913x-fe
(then remove and insert again the tuner and restart gui as last time)
Let me know and post again the log file if it still doesn't work!
After the latest Open Black Hole on line update the sound from my AVERMEDIA AVERTV VOLAR HD A835 USB is a little choppy. Here is my dvb debug file
opkg update
this work also with tuner id 048d:9135 on OBH
Thanks
Any help. The kernel-module-it913x-fe is installed but it is not working. In telnet if I try to reinstall it it says ''Package kernel-module-it913x-fe (3.13.5-r1) installed in root is up to date.''
Have you rebooted your box after the installation of kernel-module-it913x-fe module?
Just for the record and for future reference.
there is 2 tipes of avermedia and chips
[ 2.981611] usb 3-1: dvb_usb_af9035: prechip_version=83 chip_version=02 chip_type=9135
[ 2.991207] usb 3-1: dvb_usb_v2: found a 'Avermedia A835B(1835)' in cold state
[ 2.999884] usb 3-1: dvb_usb_v2: downloading firmware from file 'dvb-usb-it9135-02.fw'
[ 3.102328] usb 3-1: dvb_usb_af9035: firmware version=3.39.1.0
[ 3.108186] usb 3-1: dvb_usb_v2: found a 'Avermedia A835B(1835)' in warm state
[ 3.116954] usb 3-1: dvb_usb_af9035: [0] overriding tuner from 38 to 60
[ 3.125286] usb 3-1: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
[ 3.135060] DVB: registering new adapter (Avermedia A835B(1835))
[ 3.155350] af9033 0-0038: firmware version: LINK 3.39.1.0 - OFDM 3.9.1.0
[ 3.162202] af9033 0-0038: Afatech AF9033 successfully attached
[ 3.168208] usb 3-1: DVB: registering adapter 1 frontend 0 (Afatech AF9033 (DVB-T))...
[ 3.185934] it913x 0-001c: ITE IT913X BX successfully attached
[ 3.206990] Registered IR keymap rc-it913x-v2
[ 3.211683] input: Avermedia A835B(1835) as /devices/platform/rdb/f0470300.ehci_v2/usb3/3-1/rc/rc0/input0
[ 3.221473] rc0: Avermedia A835B(1835) as /devices/platform/rdb/f0470300.ehci_v2/usb3/3-1/rc/rc0
[ 3.230314] usb 3-1: dvb_usb_v2: schedule remote query interval to 500 msecs
[ 3.237451] usb 3-1: dvb_usb_v2: 'Avermedia A835B(1835)' successfully initialized and connected
[ 3.246280] usbcore: registered new interface driver dvb_usb_af9035
[ 3.288017] EXT4-fs (mmcblk0p4): re-mounted. Opts: nodelalloc,data=journal
[ 3.678331] random: dd urandom read with 21 bits of entropy available
AVerTV AverTV Volar HD & HD PRO (A835) with chip AF 9035
AVerMedia AVerTV AverTV Volar HD & HD PRO & Volar Green (A835B) with chip IT913X
The drivers to install are diferent.
Hope it's usefull for you.
