Bad indicator on DVB-T channels with VU+ Turbo USB
Ignatius
Dear All,
I noticed a problem after adding a USB-T head (on USB - VU+ Turbo head).
Hardware is VU+ Solo2.
On many BH versions (possibly 2.1.7 to 3.0.9) the SNR indicator does not work properly.
The indications jump from 0% to 80%, but even if it is 0% the image on TV is correct.
SNR indications are only invalid on DVB-T channels.
Everything is ok on DVB-S.
Anyone know a way to solve this problem?
Best Regards
AlexWilMac
Moderator
It is not actually a problem: so there's nothing to solve. This values and measures mean nothing. What matters is: can you watch the channel or not?
Only use of this values might be to compare two different channels. Otherwise they are just useless.
