bh 2.01 how install picons please i want to install via ftp or usb
Yeah, but my flash has only 10MB free, but if i download picons to /usb/picon my space get lower depends on the size of picons i download. Therefore t the space of the usb-universe won't used, but why?
If you`ve used the usb format wizard and after that mounted the usb stick as universe correctly your flash is as big as your usb stick.
Yes it is correctly installed but i'm using DCC_E2 to see my space and this shows me that my root space has only 10mb left. And the universe-space do not get bigger if i download picons from feed.
Is it possible that the DCC_E2 shows it "wrong" and so i can ignore the root space in DCC_E2?
On Vti+Image i used FlashExpander and there the root space was "fixed" and dosen't get lower if i installed something.
Oh thx for this :) Now i can see it on the receiver directly :D
There it is correct. Ok, then i will try to download more picons
Thanks for your help :)
I have downloaded the 28.2E picons to my Solo2 and see that part of the file names is 11A0000 yet a random check of about a dozen channels shows a service code where a part of it is 11C0000. Do I have to rename the picons manually or is there another way of getting the picons to match the channels?
