BH 2.1.1 AverMedia AverTV Volar Green HD, not working
dabezt
VU+ Solo2
BH 2.1.1
AVermedia AVerTV Volar Green HD
Tunner C: A853B (DVB-T)
Activated
Europe, Middle East, Africa: DVB-T Frequencies
5v antenna: deactivated
/usr/bin/usbtuner -V
UsbTuner v0.3.14-BETA1 (Build using DVBAPI 5.10)
cat /proc/bus/usb/devices >> /tmp/output.txt
cat: can't open '/proc/bus/usb/devices': No such file or directory
dmesg > /tmp/output.txt
lsmod >> /tmp/output.txt
cat /proc/bus/nim_sockets >> /tmp/output.txt .... see attached file
BTW: in BH 2.1.0.1 it works well.
Thnx. Cheers.
  • output.txt
angelofsky1980
BlackHole Driver Specialist
VU+ Solo2
BH 2.1.1
Activated
Thnx. Cheers.
After reading your post, seems clear that it913x devices have some problems.
I'll investigate but I need to buy a compatible device to perform best thing.
pepeluxo
The same problem.. Does not work "AVerMedia AVerTV Volar Green HD - USB TV Turner DVB-T" on image 2.1.1.
In image 2.1.0, 2.1.0.1 and earlier works fine.
Can I help?
Thanks!
angelofsky1980
Can I help?
Thanks!
I suppose you have the same device of the user that has opened this thread. At this time I can't do nothing.
First of all I need to buy a device who uses the same driver and make direct debug.
