BH 2.1.1 Streaming problem / Decoding other tuner problem
@paolino, thanks for you looking at this issue. I have not used any crypted channel, but just a few plugins which are used before. I certainly willing to do the test to get a log-file (dmesg?) in order to be invesitgated by experts as you. Would you please tell me how to get 'dmesg' ?
Telnet to your box, password root, enter command "dmesg > /tmp/dmesg.txt", next post zipped dmesg.txt (you'll find it in /tmp/ folder of your box) here.
@paolino and anyone,
I have done the experiment and my duo2 is frozen as it does. The dmesg file is uploaded as a zip file. After the receiver is frozen, the 'Blackholecmd reboot' (restart ... ) telnet commands do not work, but the 'killall -9 enigma2' will restart receiver.
Thats strange, because, when blackhole crashes, the crash log only contains that famous German STB box name !!!!!!
I don't understand what you want to say.
I'll remember, ONE MORE TIME (and I'm tired about that) that BH images derives DIRECTLY from Vu+ source code and Vu+ Company take care about licenses and other legal things.
End of story.
Same issue here, tested on a Vu solo2 and Duo 2, hd to downgrade to BH 2.1.0.1 since with 2.1.1 I couldn't use the streaming/trans-coding while watching something else on the TV
Hi, @paolino , Have you had some time to look at the dmesg file which I uploaded? Does this frozen problem is my individual issue or something else? If I update the latest driver, would it have any help? Thanks in advance.
Your issue is same as @acarlo reported - don't use saved settings from older kernel.
@paolino, Thank you very much for your reply and information. As a user, I only know where is uncomfortable, but do not know what cause these issues. We are delightly having experts as you in this community to help everyone. Thanks again, we expect VU+ will solve this issue.
I did use the old channels lists, maybe the satellites settings too, but no others. I use the DreamEditor to upload Channel list (default settings). But I do not know what are exectly included in the uploaded 'channels settings'.
I would like to thank many experts to pay attention to this issues. However, I (we) expect the VU+ pays attention for this issue.
The problem starts from Version 2.1.1.0. My DU2 does not install any abnormal plugins and all plugins which are installed have been installed in prevouse BH and never show the similar problem. I have tested using FTA channels, the problem is still there. Reflash does not resolve the issue. Recording one channel and watching another channel have no problem, but can not change the watched channal more than 3 times. If I do change the channel, the receiver will e frozen. This problem is reproduceable.
Exactly my problem. Please fix in future releases. Can anyone recommend a version that has'nt this issue?
