BH image update 2.0.5 A
Had the same issueit was router blocking the update
How did you know this? What did you do to unblock your router? Why did it block it in the first place?
I have the same problem but cannot find anything in the router about blocking particular data streams. Please explain a little more.
Thank you
Thank you
Maybe you used torrents or other hosting thsi made very big trafic on router; big trafic kill router work.
Somethimes router when work evry days block good work beocuse eoor on soft or other in this help reboot router.
Look to soft router too beocuse on rourter is big number function somethimes setup on function block others.
Hello was ist die problem ddns kan ich nicht installiren
root@vusolo2:~# opkg install ddns_0.3_mipsel.ipk
Collected errors:
* wfopen: ddns_0.3_mipsel.ipk: No such file or directory.
* pkg_init_from_file: Failed to extract control file from ddns_0.3_mipsel.ipk.
root@vusolo2:~#
Collected errors:
root@vusolo2:~#
You have tried to install an IPK from the wrong folder.
Image BH 2.0.4
****** 1.38
***** 2,3
You will be banned for 1 week for usage of EMU software
