BH3.02 - solo4k
ciao a tutti. rispolvero questo argomento perche anche io ho problemi con openvpn. ho scaricato il file di paperino61 e modificato messo in etc/openvpn. modificato il file ident con email e password di nordvpn ma niente. ho attivato il vpn sia nei moduli kernel e sia in openvpn (blu.blu)
Allego il log
grazie a tutti
Sun Jan 24 17:10:25 2021 OpenVPN 2.3.6 mipsel-oe-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Dec 11 2018
Sun Jan 24 17:10:25 2021 library versions: OpenSSL 1.0.2a 19 Mar 2015, LZO 2.09
Sun Jan 24 17:10:25 2021 WARNING: file 'ident' is group or others accessible
Sun Jan 24 17:10:25 2021 WARNING: --ping should normally be used with --ping-restart or --ping-exit
Sun Jan 24 17:10:25 2021 Control Channel Authentication: tls-auth using INLINE static key file
Sun Jan 24 17:10:25 2021 Outgoing Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
Sun Jan 24 17:10:25 2021 Incoming Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
Sun Jan 24 17:10:25 2021 Socket Buffers: R=[163840->131072] S=[163840->131072]
Sun Jan 24 17:10:25 2021 UDPv4 link local: [undef]
Sun Jan 24 17:10:25 2021 UDPv4 link remote: [AF_INET]213.232.87.137:443
Sun Jan 24 17:11:25 2021 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Sun Jan 24 17:11:25 2021 TLS Error: TLS handshake failed
Sun Jan 24 17:11:25 2021 SIGUSR1[soft,tls-error] received, process restarting
Sun Jan 24 17:11:25 2021 Restart pause, 2 second(s)
Sun Jan 24 17:11:27 2021 WARNING: --ping should normally be used with --ping-restart or --ping-exit
Sun Jan 24 17:11:27 2021 Socket Buffers: R=[163840->131072] S=[163840->131072]
Ciao Costandrea,
sei poi riuscito a risolvere questo problema ? Io continuo ad avere lo stesso e il mio log file è uguale al tuo che da problemi tls e non si connette.. le ho provate tutte e ho chiesto anche qui al forum qualche consiglio, purtroppo senza successo. Se hai trovato la causa ti sarei grato se mie la suggerissi. Io ho Vu+solo4k e, come puoi vedere da post sopra tutto funzionava bene fino a poche settimane fa. Poi ha smesso e non c'è più verso di farlo funzionare...
grazie
