Black Hole 2.0.0 doesn't refresh epg on VU+Duo
Wait a second,
first screenshot is from BH Epg (menu > epg panel - default skin) and has nothing to do with cross epg plugin;
the original one referring to cross epg providers selection menu I have already attached. Obviously with default skin.
Wait a second,
And my settings for bh built-in epg (menu > Epg Panel) attached as well...
...@a911 am I missing something???...
Thanks to all! I will try the clues posted and as soon as possible i will give feedback.
Regards from Portugal
Hello everyone,
I'm having problems with my default EPG plugin in the latest Blackhole 2.06 Rev. C.
It's not updating for some channels.
Sport TV 1 HD on MEO/ZON 30ºW is one of them. It only shows me the current program + next.
Should i use another EPG ? Like CrossEPG ?
Where can i find it ? I've browsed the available plugin list in the receiver but the plugin is not available.
Thank you. :)
Hello everyone,
Thank you. :)
Cross EPG is built in to the image. Have a look through main menu.
Thank you yummer and a911 :)
Just another thing. I should disable the one i mentioned if using this CrossEPG, right ?
Thanks. :yes:
Thanks. :yes:
You can do if you wish... I never use anything other than crossepg. I don't think you have to disable it though as you can use both. Personal preference I guess.
It's working but i have the same problem as with default EPG. Some channels don't show EPG info.
PT provider ZON changed frequencies on some channels and the new ones don't have EPG info. Guess someone at rytec have to copy paste old channel info into new frequencies.
Thank you yummer once again. :notworthy:
