Shiro
BH-C
Black Hole 2.0.5 rev. B online upgrade available.
What is new:
- Vu+ drivers update: 20130802 (duo2 solo2)
- Improve occasional sluggish skip problem.
- Change play/pause button's key code to KEY_PLAYPAUSE(duo2)
- Enhance security
- Fix several minor bugs.Fix AGC in dual tuner & Solo2 internal tuner.
- [rtl8192cu] fixed the driver to avoid network lagging during the usage.
- [mt7610u] new driver revision v3.0.0.1 and respective patches included new configuration.
- TransCodingSetup : set defalut bitrate of SOLO2.
