Ev0
Admin
Black Hole 2.1.0
- New skin by Matrix MX X Line
- New plugin Fast OpenEpg
- Updated Crossepg to the latest 0.81 version
- Updated OpenWebIf
20140424
- Fix multichannel audio problem(solo2, duo2)
20140418
- Fix DVB-S2 Single(AVL6211) tuner problem(duo2, ultimo)
- Change nim_sockets of DVB-T2 tuner(duo2, needs a E2 update)
20140403
- Fix audio problem(duo2, solo2)
20140318
- Fix dual tuner lock problem(duo2, uno, ultimo)
- Fix PCM multichannel from standby(duo2, solo2)
20140316
- Fix DDP problem(duo2, solo2)
Bh OE:
- [WLAN] Added recipe and patches for Realtek RTL8192DU driver (v4.0.0)
- Added recipe for v1.0.9 e 1.0.18 LibUSB library
- [dvb-apps-v5] updated to latest commit
- [lcd4linux] update to 4.0-r4
- [gstreamer] prevent accumulation of old cached buffers in input-selector.
- [PCSC] added recipes for CCID PCSC driver to latest version compatible with Vu OE
- [hbbtv] fix play state error on VOD
- [hbbtv/youtubetv] update vod player.
- [base-files] fix fstab
- Use ntfs-3g for mounting ntfs filesystem.
- Uupdate web-manual for vusolo2/vuduo2.
- Fix duo2 flash size.
- [Languages] updatelang: cs, el, es, fr, no, ru, sk, sv, uk.
- [NimManager] fix hasNimType for DVB-T2
- [keymap/rcinput] Adding key code for fastforward/rewind.
- [VideoEnhancement] add entry vertical_dejagging, smooth
