Black Hole 3.0.0 Vu+ Solo4k OE 3
Thanks for your replys, I can mount and play duo2 hard drive in S4k fine, in other images there is an option to copy or move files between mounts.
Do you know of a program that can batch convert my picon sizes? It has taken me ages to convert from SNP to SRP (no packages seem to have anywhere near a full set of SRP for Virgin Media.)
Cheers.
I use the ocram picons, and I thought that covered most packages now ?
As for converting them from 1 size to another, i've used image resizer for windows before to do this.
You are correct again sir , they all seem to be present in the Dirty 200x132.
I usually use the 400 ones and there was loads of Virgin HD ones missing.
P.s. The LCD XML file, where is it located after install? I would like to have a go at editing it.
Thank you.
You can now download the required files from the BH Addons server to enable front panel picons on the S4K (it is in the picons category), again you will need to use 220x132 picons
But there is a server for BH 3.0 ?
With every menu (Skins, Picons, Top 10 Downloads), the answer is:BS Server doesn't respond...
Even Weather Plugin doesn't work)...
Thank you.
it is in /etc/enigma2
Once you have had a play, feel free to start a new thread on here and post a screenshot and the xml
Sorry, I don't understand what your issue is.
Check the configuration of the network
especially DNS/nameserver
Yes this is something that Vu+ is working to fix.
In the meanwhile before to launch Xbmc you can try to switch resolution to 1080i and it should work.
I have to say i think it is a Black Hole problem..
Till Yesterday i was using VTi and it works fine on that, both interface and Movie playback.
Now on Black Hole the interface is only taking up a quarter of the screen.
Letterbox movies are being stretched to fit the screen.
I have a Samsung SUHD TV.
I have uploaded a 2nd skin_user.xml that will show the picons in the centre of the display.
Once again, this can be downloaded from the addons server.
Cheers, thats is what i was striving for, will give it a try.
Any thoughts on the xbmc? are you using a different gstreamer?
Hi
I have the same problem than @rocuelo with xbmc.
This problem occurs after the first reboot. With the image just installed xbmc is OK.
Strange no?
Thanks
The xbmc issue is being looked into.
Although if I am honest, I don't think it's a serious issue as xbmc itself is so outdated my personal feeling is vu+ would be better off spending the time to port the later version over, than to make this version work full screen.
Hi,
Another thing, i can't find information on broadcom webpage about the 7376. Its similar with BCM7251? The 7251 have wifi a.c someone know if the 7376 too?
Thanks
Nope... there was a problem with BH...
I believe it lose something on flash... because I installed plug-ins from other server, but not from BH directly...
(25 years IT experience, trust me, it not was DNS :) )
After I flashed again, work perfect...
Like I said it works correctly in VTi..
I'm sorry I have no idea on that.
Maybe @angelofsky1980 knows more ?
Vu+ has used another WIFI chipset instead to use the Broadcom suggested.
I remember that chipset used into 4K is a Ralink, but I've not remember the series.
I'm sure the chipset used is only 2.4Ghz with a maximum of 300Mbit/s (N) because I didn't see my SSID 5Ghz (I've an 802.11ac router :D with two indipendent SSIDs).
  • Like
Reactions: Ev0
