Black Hole 3.0.1C Vu+ Duo2 OE 3
Hi,
working fine on vu duo2 with lastest update for network problems..
But there is a big probleme with plugins windows and picons size in status bar.
All the windows are too small
The plugin you are referring has not a problem of skin development but a skin of the plugin used that is at least for 1280x720 HD skins and not for 1920x1080 FullHD ones.
Although you can take a look here to solve your issues --> http://www.vuplus-community.net/boa...e-1920x1080-skin-version-2.24832/#post-186287
Thanks works like a charm ;). Also used enhanced movie center and it's ok..
Last small problem with picon's size (too small). I suppose I need to search for HD 1080 picons
hi
wish you very happy new year for all forum mmbers from sri lanka
please any admin let me know when full flash will be available.should i wait or update to 3.0.1 ?
thank you....................
hi
You can install the image attached to the first post and then you can make an online update by Green Panel
Hi all,
I would like to modify the keymap.xml file to get red key opening directly the mediaplayer (TV mode).
Could someone help me, please ?
I have an issue with my HDD. It is start spinning every 30 minutes. I tryed to change acousting settings but nothing. Is there a setting to fix that?
My HDD is Seagate baracuda 2Tb...
I found the problem. Clean memory plugin settings starting HDD every 30 minutes....
A me non funziona ne telnet ne ftp,ho il ping locale da pc a vu+ 350ms di media e dovrebbe essere max 2 ms.
si collega via ftp ma non posso trasferire nessun file e cade la connessione,telnet a volte va a volte no,non sono riuscito neanche a cambiare la password root.
