Black Hole 3.0.2.F Kodi Vu+ Solo4K
Hi, before testing this image i have a question: is ci+ active and working fine in this image. I want to use the CI+ Modul from Sky...
I tried with TechniCrypt »IR CI+« Skylink and experienced some decrypting issues.
Updated to F but now image reaction is slower as with image E.
When I have to use the Timer function, after watching a movie and go back to TV mode.
Some times I can see the blue bubble left up and so on.
Gesendet von meinem SM-G935F mit Tapatalk
After a couple of weeks testing this version went back to E.
All runs smoothly again.
Will wait for the next version.
selam arkadaşlar ben karadelik Imaje yi kullanıyorum çok iyi memnunum iyi gösteriyor Fakat Bir tunerden diğerine geçtığın zaman
O tuneri görmüyor ben birinci tunere sabit turksatı ayarlamışım ikinci tunerede ilgili dört adet uydu ayarladım.cihazı kapatıp açtığım Zaman
Bir oynatıcıları görüyor yani şöyle hangi tunerde cihaz kapanıyorsa o oynatıcıları görüyor yardımlarınızı bekliyorum saygılar ...
This is International section so English is the only language allowed.
Hi,
I have VU+ Solo 4K, and when I change output to 2160P (4K) or 1080P I obtain out of sync audio with video, but when i configure to 1080i (native format of almost channels) this problem doesn't exist.
Do you think you can resolve this issue?
Thanks!
Crash occurs when zap channel with EPG data stream, while loading, after 3 seconds it crashes and generated empty log or like this:
<?xml version="1.0" encoding="utf-8"?>
<opendreambox>
<enigma2>
<crashdate>Thu Jul 21 22:58:39 2016</crashdate>
<compiledate>May 16 2016</compiledate>
<contactemail>crashlog</contactemail>
And enter into an infinte loop.
by the way, it does hapen as well with 3.0.0 and 3.0.1 I tried to test but after restore personal settings, it just enter green screen loop...
From whot version image you have personal backup ?
If im good undrestend you used he in last 3.0.2 ?
does not care about back version, I truied with older than 3.0.2, and backup setting made with last 3.0.2F, it happens all time the green screen with versions lower than 3.0.2, anyway most important problem is the crash when put epg stream channel, in this case "portada" in astra. try it!!
ohh, suddenly it works!! dont know how but now it can just stays into channel, epg data loading and end withotu problems, but I swear it was rebooting, and generating small crash log...
Hi,
Thanks!
After i begin to use a HDMI 2.0 cable, this problem disappeared.
Oh, so did you already got same issue? Actually I was using original hdmi cable, but I will test that solution...
Many thanks in advance.
