Black Hole 3.0.2.H Kodi Vu+ Solo2
Hi , First of all thanks for the Image works fine with my VU+ solo2.
I have one issue when I flash my receiver the remote responds for a few seconds then it stops.
Any suggestions how to solve this problem?
Another problem occurred, same that I had with oBH 0.6. After few days picture starts to jams, sometime gets pink for a while. Simple reset makes no change, only power off and on resolve problem... for a while.
I think I will go back to oBH 0.4 ...
Read both threads, still none the wiser. cant understand what the difference is. can some1 pls explain?
For base:
BlackHole 3.0.2 is based in O.E. 3.0 launched by Vuplus and is based in original Vuplus image.
OpenBH 06 is based on O.E. 3.4 OE-A Git.
Nothing, as expetimenting both images, can give wich from both images is the right one for you.
Hi guys. What version of NFS server does run this BH version? I posted in another thread a problem with connecting to the /media/hdd folder via nfs from other machines (I could do this perfectly in the BH 2.1.7)
hi there, just one propably silly question. as I am newbie to linux receivers - is this version of image for VU Solo 2 SE or just for Solo 2 and I should try different one e.g. one for solo se? tried to find out but couldnt.
There is no such receiver as a VU+ Solo 2 SE, that's a clone.
The official VU+ receivers, include, VU+ Solo 2, and VU+ Solo SE v2, if yours is a clone, VU+ Solo 2 SE, then I suggest you buy a genuine VU+ receiver.
Black Hole 3.0.2.H Kodi​
What is new ?​
- Implement Menu Ordering
- Support for new Matrix10 Skins
vu-new-release302-png.26855
captura-de-ecr%C3%A3-de-2016-04-07-10-14-12-1-png.26854
1-jpg.26848
2-jpg.26849
3-jpg.26850
4-jpg.26851
5-jpg.26852
6-jpg.26853
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
thanks
Hello. My Kodi 16.1 in BlackHole 3.0.2 H don't play video from LAN shares. It plays video from local disk,
it listing shares but don't play.
