Black Hole 3.0.2.H Vu+ Uno
helllo,
thank you for this new firmware
Only one thing. This relaise 3.0.x doesn't work with my dvb-t usb Pinnacle 330e
Instead firmware 2.1.7 works perfectly with Pinnacle
can you resolve this problem ?
cant install anything, even no space for channel list, in black hole speed up all disabled except backup, flash in use 99%???
Any solution?
This image has problems with AC3 sound
When playing some video with AC3 sound the sound is cut off.
Is there any solution?
Thank you very much.
I need dvb-demod-si2168-b40-01.fw and dvb-tuner-si2158-a20-01.fw , there are just working at kernel 3.19.x , Do you have any suggestions for solving this problem?
I understand.
Into BH images we don't use kernel stock drivers (and corresponding firmwares) so probably the porting can be possible.
