Black Hole 3.0.2 Vu+ SoloSE Kodi
Yesterday I switched from VTi to BlackHole (3.0.2). So far all ok.
I have one issue though:
The menu is "cut off" on the left side. How/where do I adjust the image to "fit" my (rather old) LG flat screen TV?
Thx
Unfortunately no AirPlay winth/in Kodi :(
My iPad and iPhone don't even "detect" my Kodi/BH.
Yes, I have activated the AirPlay service ;)
Many tanks for your great work.
I bought yesterday my first VU + solo SE v2, and as I have no knowledge yet.
I put this image in a Pen formatted in FAT32 and put in USB port that is under the RJ45 input, because this VU+have another USB, I think it was poorly installed it just gives me a picture Black Hole and do nothing.
What am I doing wrong?
Hi, Please could you help me to activate wireless network, I'm using Tplink TL-WN823N, I can't see the options in the menu.
Could you tell me the steps I have to do to activate the wireless usb device and the network?
Thank you
Ho configurato la mia rete per raggiungere i miei film salvati in un nas. Con quali finestre riesco a raggiungerli per poterli vedere?
hi i re-flashed my box from open vix to the new black hole but now it will not turn on it just boots up the black hole image stays on that then turns itself back off then back on to the same screen help please the box i have is the vu+ solo se v2
HI,
after updating online to 3.0.2J i cannot acess my vu+
it always gives me bad password, did it change the user root password?
Can anyone HELP me?
