Black Hole 3.0.3.A Kodi Vu+ Duo2
Hi
I have a new problem with this version :
in eutelsat 7E .
when i search , i have problem with these frequencies :
11262 H 27500
11304 H 29700
11345 H 27500
after complete search i have only 11262 .
i must search manually two other these frequency .
then i have only 11304 and 11345 .
and the channels of 11262 these frequency , changed to 11304 and noting shows .
please help me .
thanks.
Hello Bh. I have some problem to play mkv files in latest bh, works perfect in obh and bh 2.17 and 3.02 but not in 3.0.3. The mkv movie freeze
Found the error and its in vuplus not anything from Bh so i made a bugg report hope they fix it at some point
Hallo,
i am an happy user of the Vu+duo since 2013.
There is a forum saying if i can flash with 3.0.3 and (my fault i forgot) how to do it ?
Many thanks and happy new year.
Luigi
Black Hole 3.0.3.A Kodi​
What is new ?​
The Wlan options is only able to configure once. When returning to network setting theres no option for Wlan any longer?
good work but sly uk skin not compatible??????????????
What is new ?​
- Update default skin MX HQ10 to fix some plugin issues
- Update skin api to fix some plugin issues
- Update Unicable and Unicable II LNB support
1-png.28939
2-png.28934
3-jpg.28932
4-jpg.28933
5-jpg.28935
6-jpg.28936
7-jpg.28937
8-jpg.28938
INFO: This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash.
This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
This last feature offers the possibility to various forums or communities to create their favorite EPG data files and load them into a web space.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
Thanks to plnick for help obtaining missing Ultimo4K files.
Thanks to Pedro_Newbie for Backup script.
DISCLAIMER
LICENSE (TERM OF USE)
Hello BH.
i have trouble playing mkv . after about 1 minute the Movie hangs . in obh its works and in 2.17. does anyone know
Regards
Seth_72
Hi
whats happened ?
other problems not solved yet .
bh 3.0.3D that released in 25/1/2017 are not work correctly .
openwebif missed and not installed ?
please correct it .
thanks
Hi
whats happened ?
please correct it .
thanks
3.0.3.D has not been released yet.
You did online update before any announcement was made.
So you must wait now.
In the perfect world, It should never be possible to (online)update to any inconsistent state.
I guess the world is not perfect. :cool:
Best regards
Best regards
Correct it is far from a perfect world.
Also how are we supposed to know if online update will work ok for the users of the image if we do not put the updates live to test them ourselves ???
Thanks you saved me! i updated an image, and it crashed. other images refused to install, but this has worked, back to normal again. big smiles.
