Black Hole 3.0.3.A Kodi Vu+ Solo2
thanks so much
Black Hole 3.0.3.A Kodi​
What is new ?​
- Update default skin MX HQ10 to fix some plugin issues
- Update skin api to fix some plugin issues
- Update Unicable and Unicable II LNB support
1-png.28939
2-png.28934
3-jpg.28932
4-jpg.28933
5-jpg.28935
6-jpg.28936
7-jpg.28937
8-jpg.28938
INFO: This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash.
This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
This last feature offers the possibility to various forums or communities to create their favorite EPG data files and load them into a web space.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
Thanks to plnick for help obtaining missing Ultimo4K files.
Thanks to Pedro_Newbie for Backup script.
DISCLAIMER
LICENSE (TERM OF USE)
Hi.
I have problem with openmultiboot and image OpenATv5.3. When i try install this image i have message "error copying kernel". I try install VTI and no problem with openmultiboot.
You must install in flash Open Black Hole 0.6,and after this you can put in multiboot Open ATv, Vti, Black Hole etc., because Open Atv based on Open PLI images.
Hello thanks for the continuous update... keep going :-)
Question: What is the level of support of Kodi on this version? is it working without any issues?
Are there any known bugs?
Hello
I installed this version (Black Hole 3.0.3.A) and loaded personal settings from previous version.
1 - I don't have the boot logos of the new version - is it possible to download them?
2 - I am not able to run kodidirect. I have the splash screen of kodi then back to normal screens and kodi is not started.
any help ?
Thanks.
It isn't advised to load personal backups, from other versions, you can back up your channels, and Bouquets, using programs like dreamboxedit, and other files, using a FTP program, like Filezilla.
I tried this but it didn't work.
Still not able to start Kodi Launcher
And boot logo is not as the one in the screenshot.
I updated also to version C (found online) but didn't help neither.
Any other hint?
Any other hint?
If you made personal backup and restore in new version he mast work.
Somethimes when was alot changes in image or you have old backup example from version 2.1.7 but you can run on last BH. This will be gived problem.
Hello
I tried with an installation from scratch without restoring personal backup and kodi is not starting.
I can see the splash screen then nothing back to TV.
Is there a log file we can check? is it possible to download this plugin from BH srevers?
Hello
If im good remember log is setup by defoult on OBH ; in BH im no remenber now .
Bh image i think is with kodi inside when you instal image you install kodi too
On uno4k i have usb mounted to /hdd maybe kodi hiden catalog you have too on hdd or usb and have corupted file in he.
Hello
any help ?
Thanks.
1 - The bootlogo of the new version is the same from previous version, there's no reference to version number
2 - To bring Kodi back to life:
2.1. Check if your /media/hdd is well mounted.
2.2. If so, with an FTP tool connect to your STB and delete the folder ( hidden folder ) /.kodi on the root of /media/hdd.
2.2.1 Reboot your STB
2.2.2.Start Kodi launcher after reboot.
Note: You have to enable your FTP tool to show hidden folders to do what i mentioned in 2.2. ( delete /.kodi folder ).
2.2. If so, with an FTP connect ro your STB and delete the folder ( hidden folder ) /.kodi on the root of /media/hdd.
Thanks a lot - it works!
probably an old kodi directory on my hdd
No telenet and no FTP withe this image ? Help !!!
May be corrupted your file inetd.conf I had the same problem and solved replacing it with another file inetd.conf
# /etc/inetd.conf:  see inetd(8) for further informations.
# Internet server configuration database
# If you want to disable an entry so it isn't touched during
# package updates just comment it out with a single '#' character.
# <service_name> <sock_type> <proto> <flags> <user> <server_path> <args>
#:INTERNAL: Internal services
#echo        stream    tcp    nowait    root    internal
#echo        dgram    udp    wait    root    internal
#chargen    stream    tcp    nowait    root    internal
#chargen    dgram    udp    wait    root    internal
#discard        stream    tcp    nowait    root    internal
#discard        dgram    udp    wait    root    internal
#daytime        stream    tcp    nowait    root    internal
#daytime    dgram    udp    wait    root    internal
#time        stream    tcp    nowait    root    internal
#time        dgram    udp    wait    root    internal
ftp stream tcp nowait root /usr/sbin/vsftpd vsftpd
telnet stream tcp nowait root /usr/sbin/telnetd telnetd
8001 stream tcp nowait root /usr/bin/streamproxy streamproxy
8002 stream tcp nowait root /usr/bin/transtreamproxy transtreamproxy
Copy and paste it into your file etc/inetd.conf and it will work,otherwise you must reflash
scusate.....
avevo come installazione la precedentemente ver. 3.0.2I, ho fatto aggiornamento on line credendo di installare la nuova 3.0.3; mi ritrovo invece con la 3.0.2J............per avere la 3.0.3 sul mio solo2 devo riflashare d'accapo?...on line non trova + nulla
grazie
Ciao 87katia,la 3.03 A, la trovi qui : http://www.vuplus-community.net/board/threads/black-hole-3-0-3-a-kodi-vu-solo2.31181/
Una volta installata,la puoi aggiornare subito online, alla 3.03C
