Black Hole 3.0.3.G Kodi Vu+ Solo2
Hi.
Did you make permanent clock running? One from feed bricking my tuner. I tried twice - the same. Any ideas?
Thanks
qki
Hi,
I do not use IPTV. There is also pause isse after longer time ( over 5minutes) record is stuck..(yes ther is enough space on HDD :) )
I think I will come back to 3.0.2
Thanks
In last version. Of bh. The dialogue pkg (45E) hd channels audio is missing/not working. then i installed pli image then audio works perfectly. So please any one check this latest version for dialogue hd channels????
In audio panell you try setup difrent mode.
Hello, I have the same problem, Kodi Launch, but immediately close! . Could someone tell me about the dysfunction? . My Image is 3.0.3E Kodi (i also try 3.0.3G kodi) on Vu+Solo2 . Thanks in advance.
Did you have HDD or maybe USB mounted like HDD? Delete '.kodi' folder
Hi, my vu + solo² does not work IPTV list on Kodi, PVR does not want to activate, please help me .. Very grateful!
