Black Hole 3.0.3.H Kodi Vu+ Duo2
hai I'm new in the forum, I'm Italian and I'm sorry for m English, but someone can help me for installing blackhole on Kodi ?? thnx in advance
You don't need to install anything. Kodi is already included but is Jarvis (old)
Sent from my 6045Y using Tapatalk
can u tell me where I can found a tutorial for do it anything? coz I don't understand if need Kodi or not, if need a specified tv box, in few words I must start from zero
Blackhole has the older version of kodi, 16.1, Open Blackhole has the latest Kodi 17.3 krypton.
From meory, to load kodi, on Blackhole, just go to the plugins, download, and install kodi, a simpler, smaller, version is the IPTV player, also downloaded from plugins.
I
3.0.3 P when try grab screenshot from WebIf get this error
web.Server Traceback (most recent call last):
<type 'exceptions.AttributeError'>: 'eConsoleImpl.eConsoleAppContainer' object has no attribute 'setBufferSize'
/usr/lib/python2.7/site-packages/twisted/web/server.py, line 132 in process
130 try:
131 resrc = self.site.getResourceFor(self)
132 self.render(resrc)
133 except:
/usr/lib/python2.7/site-packages/twisted/web/server.py, line 167 in render
165 """
166 try:
167 body = resrc.render(self)
168 except UnsupportedMethod, e:
/usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/grab.py, line 86 in render
84 # Add a reference to the grabber to the Request object. This keeps
85 # the object alive at least until the request finishes
86 request.grab_in_progress = GrabRequest(request, self.session)
87 return server.NOT_DONE_YET
/usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/grab.py, line 48 in __init__
46 self.container.appClosed.append(self.grabFinished)
47 self.container.stdoutAvail.append(request.write)
48 self.container.setBufferSize(32768)
49 self.container.execute(GRAB_PATH, *graboptions)
Hi, mates
Thanks for the great work.
Can you tell me if is possible to install ps4 remote play on enigma2 vu?
Is there any plugin? Or add on?
Thanks
Where have enigma 2 catseye channel lists gone from blackhole settings? I've always used this channel list and I have no idea how to get it on there manually. The only channel lists available are by vhannibal. I've tried uploading a channel list from VUCC and it says it's been successful but when I reboot my box it's nowhere to be seen and I just can't find it. Somebody please help? I don't use my box very much and I am by no means an expert, literally on the brink of having to get rid of it.
Use Dreamboxedit, or Dreamset.
Download dreamboxedit, open it, go to the Tools bar, and Options, type in your receivers IP address, click test IP Connection, and if it's working save.
Right click, on your PC desktop, select New Folder, and name it settings.
Now go to File, and Open, navigate to the channel list and open.
If satisfied go to File, FTP, Send Files to Dreambox.
http://www.vuplus-community.net/board/threads/dreamboxedit.18975/page-2
Thanks a lot!!!
Hey, while I'm around such helpful and friendly people... Can somebody tell me how I can find and add picons as well?
BH3.0.3Q
Vu+ PlayerHD for iPhone & iPad (v1.40) ( Connecting ... Connection fails )
Vu+ PlayerHD for Android (v1.2.1) ( Connecting ... Connection fails )
Webif stream (VLC) ( ok )
Do anybody using BH3.0.3 have a stable running Vu+ PlayerHD ?
BH3.0.3Q
Vuplus player havent worked since 2.17 is latest version it worked in .
