Black Hole 3.0.3 Kodi Vu+ Duo2
It can be anything even from vuplus. Before it was dreambox that used enigma2 as opensource and vuplus used that then dreambox change their software , what i heard was that dreambox wanted to sue vuplus .now maybe vuplus have some problems with coding .and if it s so then bh willmalso get problem like now with emc and other plugin which makes more job for bh.im leaning to use obh on both my boxes. Will not leave Black hole , not yet .ihope that i will be better soon . Still have problem with vuplus player and dts codec. We will maybe see some fixes later on .
And what to say
we are not happy when something does not work.
I see the same errors as you.
They were not in BH 3.0.2.
So it is clear where is the problem.
Merry Christmas from the Black Hole Team
Black Hole 3.0.3 Kodi​
What is new ?​
- Add Support for Uno4K and Ultimo4K
- Update default skin MX HQ10 for extra tuners
- Update skin api
- Update OpenMultiboot
1-png.28939
2-png.28934
3-jpg.28932
4-jpg.28933
5-jpg.28935
6-jpg.28936
7-jpg.28937
8-jpg.28938
INFO: This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash.
This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
This last feature offers the possibility to various forums or communities to create their favorite EPG data files and load them into a web space.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
Thanks to plnick for help obtaining missing Ultimo4K files.
Thanks to Pedro_Newbie for Backup script.
DISCLAIMER
LICENSE (TERM OF USE)
What is new ?​
- Update skin api
1-png.28939
2-png.28934
3-jpg.28932
4-jpg.28933
5-jpg.28935
6-jpg.28936
7-jpg.28937
8-jpg.28938
Addons
Infobar / OSD
Analog Clock Gui
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
UPnP Client Djmount
Pcsc Panel
Tuner Server
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
And what to say
Sorry didnt mean any thing to Team Bh , on the other i give Team Bh all credit for very good job. I wrote to simon123, but see his replys and messsages are gone.?
I have my problems as usual with WLAN connection, tried several times but cant get it to run.Nevertheless thank you for the update.
Hi,
This version cannot update/ upgraded via online? Tried several times but nothing to.
Thank you in advance your response
Jose
Hi,
Jose
You can not upgrade from an earlier version to 3.0.3 it is a clean re-install update.
However there is now 3.0.3.A so better to flash that image instead.
What is new ?​
- Update skin api
1-png.28939
2-png.28934
3-jpg.28932
4-jpg.28933
5-jpg.28935
6-jpg.28936
7-jpg.28937
8-jpg.28938
Addons
Infobar / OSD
Analog Clock Gui
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
UPnP Client Djmount
Pcsc Panel
Tuner Server
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
thanks
thanks for the great image
I have a problem since 3.0.3 where after i set the vu+ due 2 up with this image from a backup or new the wifi connects and works fine but after about 5 - 10 mins my networks wifi internet will slowdown to an unusable state untill i reboot the vu then will be fine for abot 5 - 10 mins again. I have updated to 3.0.3A and 3.0.3B and still have the same fault if i run 3.0.2 or and earlier version of blackhole my internet stays fine
thanks
cozmo
thanks
cozmo
I can only assume it's a driver issue, as thats the only thing that has changed that could cause that issue.
There has been new drivers released today, so maybe in the next update, that issue will be resolved.
I can only assume it's a driver issue, as that's the only thing that has changed that could cause that issue.
I have installed the new 3.0.3c and still have the same problem with wifi killing my internet seems a little better than 3.0.3 , a and b but still not right i will say on 3.0.2j for now and try a later version
thanks for your help Evo
Cozmo
Cozmo
No problem, atleast that seems to confirm that it is a driver issue, just a shame there is nothing we can do, we just have to wait for vu+ to fix it.
Cozmo
What sort of router do you have. open upnp on your router, perhaps a longshot may work
