Black Hole 3.0.4.C Vu+ Solo2
On openBH it is possible to setup the buttons of channel history ( < and >) to show the channel history instead of directly zapping between history channels. Is it possible to set this up on this version?
Thanks
1) when I move in the Menu (any) for a few seconds stops, then jumps for 2-3 channel or stop for few seconds for a exit!
2) PIP does not work correctly - does not switch channels with the '0' button!!
3) in Youtube does not rewind forward -1-2 minutes and is stopped!!!
check, please
check, please
I noticed such lag when enabling picons in the channel list. Is it a bug?
hi, thanks,
but this bug appeared immediately after the firmware 3.0.3 C, later I downloaded (online) 3.0.4 D but the bug remained!
do you not have such problems?
No solution, waiting for developers to give feedback on this.
I might go back to open blackhole, it is really slow.
