Black Hole 3.0.4.C Vu+ SoloSE
Ev0
Admin
Black Hole 3.0.4.C
What is new ?
- Update CrossEPG Providers
- Update [opera-hbbtv] to fix youtubetv transparency issue
1-png.31518
2-jpg.31506
3-jpg.31507
4-jpg.31510
5-png.31514
6-png.31513
7-jpg.31516
8-jpg.31509
9-jpg.31511
INFO: This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash.
This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
This last feature offers the possibility to various forums or communities to create their favorite EPG data files and load them into a web space.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
Thanks to plnick for help obtaining missing Ultimo4K files.
Thanks to Pedro_Newbie for Backup script.
DISCLAIMER
LICENSE (TERM OF USE)
  • BlackHole-3.0.4-vusolose_usb_release_20171018_fa35b14.zip
Ray69
After flashing image, chanel change takes ~2 minutes! Transponder check on Satfinder and Manual scan works fine.
Savasgr
imdb Plugin does not produce any results(no details found) even if you search titles with english characters
The clock does not change whichever timezone has been selected
kabr3r0
Hi,
I have some issues with the ac3 codec in BH 3.0.4 while playing .mkv (audio appears and disappears constantly).
Is it solved in 3.0.4.C?
Thx
kabr3r0
Hi,
Thx
Well I decided to check it by myself and I can say it's not fixed yet...so coming back again to BH 2.1.7 on which ac3/a52 audio works perfect...
