Black Hole 3.0.4 Vu+ Duo2
Ev0
Admin
Black Hole 3.0.4
What is new ?
- Add Quad Picture in Picture support (Ultimo4K, Uno4K, Solo4K)
- Update CrossEPG to support new Rytec xz compression XMLTV listings
- Update CrossEPG to include latest Rytec Providers
- Update OpenWebif to fix Grab and WebTV
- Update Drivers (Ultimo4K, Uno4K, Solo4K, Duo2, SoloSE, Solo2, Zero)
- Fix FCC to work with usb tuners (Ultimo4K, Uno4K, Solo4K)
- Update Bluetooth Support (Ultimo4K, Uno4K, Solo4K)
- Update default skin to support Quad PiP
- Update Italian translations
1-png.31518
2-jpg.31506
3-jpg.31507
4-jpg.31510
5-png.31514
6-png.31513
7-jpg.31516
8-jpg.31509
9-jpg.31511
INFO: This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash.
This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
This last feature offers the possibility to various forums or communities to create their favorite EPG data files and load them into a web space.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
Thanks to plnick for help obtaining missing Ultimo4K files.
Thanks to Pedro_Newbie for Backup script.
DISCLAIMER
LICENSE (TERM OF USE)
  • BlackHole-3.0.4-vuduo2_usb_release_20170909_0782c55.zip
satelit
Morning Guys ,
I was looking for a new Image . I will try it tonight.
Until than : great job !!!
Thank you all for your hard work here.
Respectfully ,
S_H
satelit
Great image team .
Everything is running flawless ...
Thank you once again for giving us these great images.
S_H
Overix
Hi. I want report about big problem. Wi fi absolutely didnt work without install "WirelessLan" Extension, i try connect to 2 wifi network and use DHCP and static IP settings - nothing. I fix that like this - i connect to VU+ Duo 2 wired LAN and share internet then install "WirelessLan" extension. After that problem with Wi FI was solved and all start work perfect. Dear developers please add "WirelessLan" extension in next firmware by default. Thanks for fresh firmware.
JtagPabb1e
Thanks for this, I'm new to my Duo 2 and only tried openvix but i have some slight stutter on the HD channels so i hope i don't see this in the black hole image.
