Black Hole 3.0.4 Vu+ Ultimo4K Quad PiP
Hello, I do not achieve that the epg works of movistar + (Rytec spain). There is some solution?
Thank you.
Hi all
quadpip question...?
I have
vuultimo 4k
1 fbc cable tuner
1 fbc s2 tuner
I goto pip selection
select 4 channells
but only one channel is displayed, I get 4 pip squares but only 1 channel show.
I tried 4 channells on S2
I tried 4 channells on Cable tuner
same affect on both.
Any help thank you in advance
Report: After first TDT scan all the new TDT scan found no channels (all terrestrial transciever FAILED). The TDT reciever is the official Vu+ twin TDT-T2/C. Aynone? I 'll try to reinstall full image.
UPDATE: After reinstalling the image I found the terrestrial transcievers again in several frequencies. I'm no sure if it's a image problem or maybe I touched some configurations and messed up the reciever...
