Black Hole 3.0.4 Vu+ Zero
i fixed problem with openvix.
here is a problem when update online.
overload flash..
back again at blackhole .this is fuckin the best image.
but no more update online.
Image seems perfect, but with IPTV i don't have sound in some channels... with others images it works... i don't think it depends on my iptv list...
BTW, i think it's the most stable version ever made.
Hello, is it normal that i can't update my current version (BlackHole 3.0.3.0) to this newest one?
When i do update it says that "There's no update for you"
[edit]
"This is available as a full flash update only"
Ok, now i know :X
BTW, is there any way to install it, and save my setting and plugins?
[edit]
Ok, now i know :X
Make a copy of your settings. You can use BlackHole Settings BacKup, dreamboxedit or dreamset tools.
All the plugins, you must install from scratch, after setting up your "new" running image.
Hi guys,
First of all, thanks for you great job.
I installed this version from scratch and CrossEPG doesn't work properly. Rytec XMLTV Spain is not doing anything. After downloading, EPG info is empty.
Could you help me?
Hi guys,
Could you help me?
You update to last version Bh 3.0.4A ?
Black Hole 3.0.4​
What is new ?​
- Add Quad Picture in Picture support (Ultimo4K, Uno4K, Solo4K)
- Update CrossEPG to support new Rytec xz compression XMLTV listings
- Update CrossEPG to include latest Rytec Providers
- Update OpenWebif to fix Grab and WebTV
- Update Drivers (Ultimo4K, Uno4K, Solo4K, Duo2, SoloSE, Solo2, Zero)
- Fix FCC to work with usb tuners (Ultimo4K, Uno4K, Solo4K)
- Update Bluetooth Support (Ultimo4K, Uno4K, Solo4K)
- Update default skin to support Quad PiP
- Update Italian translations
1-png.31518
2-jpg.31506
3-jpg.31507
4-jpg.31510
5-png.31514
6-png.31513
7-jpg.31516
8-jpg.31509
9-jpg.31511
INFO: This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash.
This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
This last feature offers the possibility to various forums or communities to create their favorite EPG data files and load them into a web space.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
Thanks to plnick for help obtaining missing Ultimo4K files.
Thanks to Pedro_Newbie for Backup script.
DISCLAIMER
LICENSE (TERM OF USE)
muito obrigado ,
Please help me.
VU+Zero 3.0.4 A-on YouTube not working, when the video starts there's only sound, no picture.
I need softver team's help.
Thanks in advance.
Please look to other topic about youtobe problem you find answered for your problem.
Now youtobe work on iptv player and on youtobe plugin [ you find he on feed updated by Matrix10 ].
No work on VU+ YouToubeTV
Yes I did it. I updated to 3.0.4A.
When I try to download I got the messages down the screen but everything goes too fast and I don't get the EPG data. I´ve been using BH 3.0.2J until few weeks ago CroosEPG stopped working.
