NEW UPDATE ONLONE FOR BLACK HOLE IMAGE 3.0.5 K BUT there is a bug in last update of black hole image online 3.0.5k all the transponders in HORIZONTAL not working i try every thing but only one solution i downgrade to previous version please fix it soon
Write more info; whot reception ?after update no more reception, back to vti
Please post crashlogSolo 4K updated to V.3.0.5.K
The lan dont work- The Wifi Works ok.
Self reset when load epg from digital channel... No green screen.
Good job!!!!
Thanks
Which digital channel? If it's Portada channel on 19.2E, then the solution is here:Self reset when load epg from digital channel
how do i search in blind scan mode?
thx.
