Black Hole 3.0.5.I Vu+ Duo2
Does YouTube TV work properly in this version? Please let me know....thanks guys
This orginal made by VU+ no.
But you have possibility install other plugins who suport youtobe good. [ look to version posted by nunigaia ] or install iptv player and he have youtobe host too.
Then install the plugin and restart Enigma2
Most often the receiver does not go up
And you have to turn the receiver back on and off. Please fix this problem in the next update. Thank you
Hello,
I have exactly the same problem. Try to reload your skin. This resolves the problem temporarily.
Any other suggestion for this issue?
Hi, the Transcoding icon is not shown in OpenWebif, but if I edit the normal stream link to port 8002 it works fine. Will you introduce the icon again for those with an active Transcoding?
Hi, tested yesterday on my Vu+Duo2 and get reboots (starts and shutdown constantly)
Can´t find the reason or an problem.
I would appreciate any help
