Black Hole 3.0.5.I Vu+ Zero4K
Hi,
I have the same problem than scorpion007. I can not update online Black Hole 3.0.5.I because it crashes on udev with a green screen.
Would be possible to launch a new version to install without online update or get a newer image?
Thank you very much.
There are no more updates for 3.0.5
Wait a new image
hello
what about from this plguins
opkg update
opkg install ffmpeg
opkg install exteplayer3
opkg install enigma2-plugin-systemplugins-serviceapp
not matched
i can't installed this plugins from the Feed
i want to use plugin exteplayer3 ...
plz help me
bad image .....:mad::wallbash:
Why a bad image?
Because there is not what you need?
Those are two different things.
So we make two images.
One for the fans of the classics Sat TV where is BH image super image
and those who use multi media or something else that does not support VU + and BH coding.
So BH is a super image for what it supports.
Why a bad image?
i install the image two times has external flash
I have a server that activates with a plugin
after activation all work good
but when change another image and then back to blackhole the server does not work and the activation is wrong and there is no connection with the server for activation other times ...coonecting error ...Comparison the other images openpli + openblackhole + openatv the problem happens on blackhole if all
I did not understand everything.
but Does not matter.
I use Black Hole image to watch SAT TV and there is Black Hole superior.
Everything else is a matter of need and interest.
That is why there are other images as well.
If this is a problem with the Black Hole and Open Black Hole server,
this is not related to the image but to the problems we have with the server
lately.
