Black Hole 3.0.7 Vu+ Duo2
BH3.0.7 build: 2018-12-05-master
FYI:
"Online Black Hole Image Update" keeps finding the same 3 package to update. ?
Best regards
Yes, exactly, so you should also change the <Blue> <Red> (Epg-settings) so it is opening the new "EPG sub menu".
Thx
Best regards
I talked to the coder.
We will do this in the next image.
Now to change only this is to big job ,to change in the image and in 40 skins with new panel and update all on the server.
hallo,
sorry for my english
i search monthly for the buffering of iptv channels
live stream channels are freezed by me
how can i edited it or installed plugin ..?
thx
hallo,
thx
Try our Open Black Hole image if you use IPTV and have problems.
Hi AND thanks for The image. I ha e a vu+ ser 4K and I’m new with this box so I have some questions about upgrade:
1.- Is it mandatory to install the upgrade because version 3.0.6 will no longer be supported?
2.- Is it correct to do it via usb and not online?
3 .- I have a backup made by the deco itself but I read that once you update you will not read it to be from an earlier version.
4.- If this is so, I have to copy my folders in etc and then paste them with filezilla? I would not like to lose the list of channels or the picons either.
Many thanks in advance
Enviado desde mi iPad utilizando Tapatalk
1. BH 3.0.6 no more updates
2.flash BH 3.0.7 via USB
3.You better not use a backup. Possible problems.
4.Backup satellite list (for example) with dreamboxedit
You can copy only certain files to PC
which you need for a new configuration or edit and not the whole etc and folders
Can you please, tell us which vuplus model you are using. Ok Vuplus 4K, but the model?
Same problem here also on Ultimo4k
Why posting on the section related to Vuplus Duo2 model?
Here, you are both "OFF TOPIC".
Note: Please don´t mix threads.
Again: you are in the wrong section (so OT, as Ev0 remarked) and, also, for a specific problem, create a specific thread, please, without using the general one.
Hi, this morning was made upgrade from 3.0.6 BH in Vu +. zero 4k but I have a problem with my picons so that main cover in every short channel, they have an extra size and I'm not know how I can change. Add images. Thanks in advance for your help ;)
Do you use the appropriate picons
size 220x132
Ups this is about Duo 2 .
Thanks for the new image. I do have problems in both versions 3.0.6 and 3.0.7! I can`t find any channels from thor 0,8w and astra 4,8e. They are in the list but after scan i get 0 services. How to fix this. They have worked before today on 3.0.5 before the upgrade. Help
Check that they aren't listed at Thor 1W, and 4.9E, in the satellites XML file.
It might be easier to do a manual scan, of a known working transponder, on each satellite, using the 1W, and 4.9E, options.
Yeah Thor is listed at 0,8w so i don`t know what is wrong. I tried both with automatic scan and manual scan and still no luck.
In this new image you can choose between ku-band and c-band, but i guess ku band is the one.
Hotbird 13e works just fine.
KU band is the one, also look out for KA band.
Have you tried selecting 4.9E, and 1W, in your options?
Can you please post your satellite setup, Fixed dishes, multiple LNB's, with Diseqc switch, Motorized dish, dish size, general location, etc., and how you've got your tuner configured.
