Black Hole 3.0.7 Vu+ Zero4K
Thank you for reply.
No. OBH it has many problems. I always force to reinstall the image, that's why I'm looking for these features
Well you won't find them in BH and if you don't like OBH, then you need to look elsewhere, but I think those features are only found on OE-A / PLi based images.
  • Like
Reactions: ssj
Thank you very much for your help. Yes, it exists in openpli.
Really? And what problems does it have, please? I'm curious, as I'm using OBH since its very experimental 0.4 and, since 0.6, it became so reliable that I've been using it as main and now ONLY image.
Simply and without touching anything, shutdown at night and in the morning does not start. So I reinstall. It is a nuisance.
It's just a your issue, surely not general. Check if there is any PowerTimer set and remember that, in case there is one that put it in DeepStandby, the switching on needs time.
Or maybe there is some device attached that causes this problem.
Can you image how many messages about such an issue we'd have if this problem was general? ;)
Before this happens to me every month once, but in the last weeks it happens to me almost every day. I did not touch anything in the system.
Only once did it crash when i played an iptv. Then almost every day with the same problem, the image does not start
I decided to look for another image.
Im sorry, but 3.0.7 can not play movies in 4K from usb!
VTI 14.0 in same machine without problem, any 4K HDR, 50 GB.
I think play,.
Write more info about your video who is no possible play.
Im try now uhd in H264 and play too .
P.s maybe your usb is wrong mounted on BH image ?
Hi, I have noticed if I install BH307 in flash the HDD works fine, if I have OBH4.2 in the flash memory and BH307 in multiboot it will not allow the HDD to work with the BH307 image. Is this normal as I have not had this with previous version?. Thanks for any advise.
Yes, I posted about that almost immediately. This also makes impossible to record by BH and this is a serious problem. Even if I don't want to use BH any longer, it's useful to have it fully working in omb for tests' purpose or for other comparisons.
I underline this problem for the developers. Le't see what happens with the 308 that seems is already arriving.
tengo esta imagen instalada, y se podria actualizar en linea , o hay que hacer todo el proceso de bajar otra version e intalar todo de nuevo?
saludos y gracias
NO, as ALWAYS, getting from a version to the next is not an update, but it is an upgrade. You need to reflash. As written many times, you can save your channels and bouquet by a software or simply by the WebIF and its bouquet editor.
