Hi! In Black Hole 3.0.8 my USB DVB-T device is not working (in 3.0.7 and all the oldest firmwares works ok). It's an August DVB-T202 device.
Here u have the dvb_debug File if it can help you. Thank you very much!
Box Info
Kernel: Linux vuzero 3.13.5 #1 SMP Mon Dec 10 23:35:24 UTC 2018 mips GNU/Linux
BH Ver: BlackHole 3.0.8
USB devices
Bus 001 Device 002: ID 048d:9006
Bus 001 Device 001: ID 1d6b:0002
Bus 002 Device 001: ID 1d6b:0001
Kernel Messages
pcpu-alloc: [0] 0 [0] 1
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048
Kernel command line: ubiroot rootflags=sync bmem=192M@64M ubi.mtd=rootfs rootfstype=ubifs root=ubi0:rootfs libata.force=1:1.5Gbps
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 315172K/524288K available (6090K kernel code, 279K rwdata, 1220K rodata, 204K init, 114K bss, 209116K reserved)
Hierarchical RCU implementation.
RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
NR_IRQS:160
Measuring MIPS counter frequency...
Detected MIPS clock frequency: 751 MHz (375.761 MHz counter)
Calibrating delay loop... 749.56 BogoMIPS (lpj=374784)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
SMP: Booting CPU1...
CPU1 revision is: 0002a065 (Broadcom BMIPS4380)
FPU revision is: 00130001
Primary instruction cache 32kB, VIPT, 2-way, linesize 64 bytes.
Primary data cache 64kB, 4-way, VIPT, cache aliases, linesize 64 bytes
SMP: CPU1 is running
Brought up 2 CPUs
devtmpfs: initialized
NET: Registered protocol family 16
USB0: power enable is active high; overcurrent is active low
bio: create slab <bio-0> at 0
SCSI subsystem initialized
libata version 3.00 loaded.
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Advanced Linux Sound Architecture Driver Initialized.
cfg80211: Calling CRDA to update world regulatory domain
Switched to clocksource wktmr
FS-Cache: Loaded
NET: Registered protocol family 2
TCP established hash table entries: 4096 (order: 2, 16384 bytes)
TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP: reno registered
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
Registering unionfs 2.5.13 (for 3.13.7)
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
nfs4filelayout_init: NFSv4 File Layout Driver Registering...
Installing knfsd (copyright (C) 1996
okir@monad.swb.de).
msgmni has been set to 615
io scheduler noop registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0x10406800 (irq = 62, base_baud = 5062500) is a 16550A
console [ttyS0] enabled
bootconsole [early0] disabled
serial8250.0: ttyS1 at MMIO 0x10406840 (irq = 63, base_baud = 5062500) is a 16550A
serial8250.0: ttyS2 at MMIO 0x10406880 (irq = 64, base_baud = 5062500) is a 16550A
loop: module loaded
ahci strict-ahci.0: can't get clock
__clk_enable: sata [1]
ahci strict-ahci.0: SSS flag set, parallel bus scan disabled
ahci strict-ahci.0: AHCI 0001.0300 32 slots 2 ports 6 Gbps 0x3 impl platform mode
ahci strict-ahci.0: flags: ncq sntf stag clo slum part
scsi0 : ahci_platform
scsi1 : ahci_platform
ata1: FORCE: PHY spd limit set to 1.5Gbps
ata1: SATA max UDMA/133 mmio [mem 0x10181000-0x10190fff] port 0x100 irq 87
ata2: SATA max UDMA/133 mmio [mem 0x10181000-0x10190fff] port 0x180 irq 87
brcmstb_nand: NAND controller driver is loaded
__clk_enable: network [1]
__clk_enable: enet [1]
bcm7552_pm_genet_enable 00
bcmgenet: configuring instance #0 for internal PHY
bcmgenet bcmgenet.0 eth0: link down
__clk_disable: enet [0]
bcm7552_pm_genet_disable 00
__clk_disable: network [0]
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
__clk_enable: usb [1]
bcm7552_pm_usb_enable 00
ehci-brcm ehci-brcm.0: Broadcom STB EHCI
ehci-brcm ehci-brcm.0: new USB bus registered, assigned bus number 1
ehci-brcm ehci-brcm.0: irq 66, io mem 0x10480300
ehci-brcm ehci-brcm.0: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci-brcm ohci-brcm.0: Broadcom STB OHCI
ohci-brcm ohci-brcm.0: new USB bus registered, assigned bus number 2
ohci-brcm ohci-brcm.0: irq 67, io mem 0x10480400
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
usbcore: registered new interface driver usb-storage
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
Success! Registering the characther device success with 0
blackhole initialised
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
hidraw: raw HID events driver (C) Jiri Kosina
ata1: SATA link down (SStatus 0 SControl 310)
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
TCP: cubic registered
Key type dns_resolver registered
PM: CP0 COUNT/COMPARE frequency does not depend on divisor
EBI CS0: setting up NAND flash (primary)
NAND device: Manufacturer ID: 0xad, Chip ID: 0xda (Hynix H27U2G8F2CTR-BC)
NAND device: 256MiB, SLC, page size: 2048, OOB size: 64
brcmnand brcmnand.0: 256MiB total, 128KiB blocks, 2KiB pages, 16B OOB, 8-bit, Hamming ECC
Bad block table found at page 131008, version 0x01
Bad block table found at page 130944, version 0x01
Creating 4 MTD partitions on "brcmnand.0":
0x000002100000-0x000010000000 : "rootfs"
0x000002100000-0x000010000000 : "rootfs(redundant)"
0x000000200000-0x000000900000 : "kernel"
0x000000900000-0x000000a00000 : "mac"
UBI: attaching mtd0 to ubi0
usb 1-2: new high-speed USB device number 2 using ehci-brcm
ata2: SATA link down (SStatus 0 SControl 300)
input: ITE Technologies, Inc. USB Deivce as /devices/platform/ehci-brcm.0/usb1/1-2/1-2:1.1/input/input0
hid-generic 0003:048D:9006.0001: input,hidraw0: USB HID v1.01 Keyboard [ITE Technologies, Inc. USB Deivce] on usb-ehci_hcd-2/input1
random: nonblocking pool is initialized
UBI: scanning is finished
UBI: attached mtd0 (name "rootfs", size 223 MiB) to ubi0
UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
UBI: good PEBs: 1780, bad PEBs: 4, corrupted PEBs: 0
UBI: user volume: 1, internal volumes: 1, max. volumes count: 128
UBI: max/mean erase counter: 56/31, WL threshold: 4096, image sequence number: 236582649
UBI: available PEBs: 0, total reserved PEBs: 1780, PEBs reserved for bad PEB handling: 36
UBI: background thread "ubi_bgt0d" started, PID 53
ALSA device list:
No soundcards found.
UBIFS: parse sync
UBIFS: background thread "ubifs_bgt0_0" started, PID 56
UBIFS: mounted UBI device 0, volume 0, name "rootfs"
UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
UBIFS: FS size: 219541504 bytes (209 MiB, 1729 LEBs), journal size 9023488 bytes (8 MiB, 72 LEBs)
UBIFS: reserved for root: 0 bytes (0 KiB)
UBIFS: media format: w4/r0 (latest is w4/r0), UUID F58F0735-DD87-4582-A137-9B0E1F7B5D17, small LPT model
VFS: Mounted root (ubifs filesystem) on device 0:13.
devtmpfs: mounted
Freeing unused kernel memory: 204K (8076d000 - 807a0000)
udevd[103]: starting version 182
WARNING: You are using an experimental version of the media stack.
As the driver is backported to an older kernel, it doesn't offer
enough quality for its usage in production.
Use it with care.
Latest git patches (needed if you report a bug to
linux-media@vger.kernel.org):
90173108f25ee792a5c3595c5467fb9a9c8d8a73 rename v4l2 some more func
aba254366fa2c9446165f916917aee27162cb354 rename v4l2 some more func
ff7c56ae372c05845f30415a4ef264b34bedb4ac rename v4l2 some more func
Use it with care.
procmk_init
usb 1-2: dvb_usb_af9035: prechip_version=83 chip_version=02 chip_type=9135
UBI error: ubi_open_volume: cannot open device 0, volume 0, error -16
usb 1-2: bh_dvb_usb_v2: found a 'ITE 9135(9006) Generic' in cold state
usb 1-2: bh_dvb_usb_v2: downloading firmware from file 'dvb-usb-it9135-02.fw'
usb 1-2: dvb_usb_af9035: firmware version=3.39.1.0
usb 1-2: bh_dvb_usb_v2: found a 'ITE 9135(9006) Generic' in warm state
usb 1-2: dvb_usb_af9035: [0] overriding tuner from 00 to 60
usb 1-2: bh_dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
DVB: registering new adapter (ITE 9135(9006) Generic)
i2c i2c-0: af9033: firmware version: LINK=0.0.0.0 OFDM=3.9.1.0
usb 1-2: DVB: registering adapter 1 frontend 0 (Afatech AF9033 (DVB-T))...
usbcore: registered new interface driver dvb_usb_af9035
dvb_bcm7362: module license 'Proprietary' taints kernel.
Disabling lock debugging due to kernel taint
DVB: registering new adapter (_vuplus_zero_)
bcm7362: hotplug_callback():
Hotplug - status.connected 1:0:0
Hotplug - connecting HDMI to display 0xe
[GP]:brcm_pwm_init
brcm_demux_init: $Id: bcm_demux.c,v 0.7 $
Hotplug - status.connected 1:1:2
[MPVR]: >> misc_pvr_init
[VID]: 6bcm7335_video_init
[AUD]: 6bcm7335_audio_init
BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (BCM7362 FE)...
input: dreambox advanced remote control (native) as /devices/virtual/input/input1
[LCD]: registered
0:0
[DFP]: registered dbox fp
[SC]: registered sci0
system_time_set wakeup mode get
system_time_set wakeup mode get 0xc4
fpga update driver loaded
[VID]: VIDEO_SET_STREAMTYPE 0
[VID]: VIDEO_SELECT_SOURCE 1 0
[VID]: VIDEO_PLAY 1 2 0
[VID]: VIDEO_CONTINUE 1 1
[VID]: VIDEO_CLEAR_BUFFER 1 1 0
[VID]: VIDEO_STOP 0 1
[VID]: VIDEO_SELECT_SOURCE 0 0
bcmgenet bcmgenet.0 eth0: link up, 100 Mbps, full duplex
NET: Registered protocol family 10
[LCD]: unknown cmd 0x1015
[AUD]: AUDIO_SET_MUTE 0
[AUD]: AUDIO_SET_MIXER -1365844496
[AUD]: AUDIO_SET_MIXER : amixl 0, amixr 0
[AUD]: AUDIO_SET_MIXER : next left volume 0, right volume 0
[AUD]: AUDIO_SET_MIXER : next left volume -70, right volume -70
NIM Sockets
NIM Socket 0:
Type: DVB-S2
Name: BCM7362 DVB-S2 NIM (internal)
Frontend_Device: 0
Modules Loaded
Module Size Used by
ipv6 332460 26
fpga_directc 493 0
brcmfb 1590 3
dvb_bcm7362 6651605 1 brcmfb
af9033 25135 0
dvb_usb_af9035 14834 0
bh_dvb_usb_v2 14745 1 dvb_usb_af9035
procmk 1668 1 dvb_bcm7362
bh_rc_core 18885 2 bh_dvb_usb_v2,dvb_usb_af9035
bh_dvb_core 87582 1 bh_dvb_usb_v2
ext2 57304 0
Kernel Objects
/lib/modules/3.13.5
/lib/modules/3.13.5/modules.builtin.bin
/lib/modules/3.13.5/modules.symbols.bin
/lib/modules/3.13.5/kernel
/lib/modules/3.13.5/kernel/fs
/lib/modules/3.13.5/kernel/fs/fat
/lib/modules/3.13.5/kernel/fs/fat/msdos.ko
/lib/modules/3.13.5/kernel/fs/nls
/lib/modules/3.13.5/kernel/fs/nls/nls_cp850.ko
/lib/modules/3.13.5/kernel/fs/ext2
/lib/modules/3.13.5/kernel/fs/ext2/ext2.ko
/lib/modules/3.13.5/kernel/fs/fuse
/lib/modules/3.13.5/kernel/fs/fuse/fuse.ko
/lib/modules/3.13.5/kernel/fs/ntfs
/lib/modules/3.13.5/kernel/fs/ntfs/ntfs.ko
/lib/modules/3.13.5/kernel/fs/reiserfs
/lib/modules/3.13.5/kernel/fs/reiserfs/reiserfs.ko
/lib/modules/3.13.5/kernel/lib
/lib/modules/3.13.5/kernel/lib/crc-ccitt.ko
/lib/modules/3.13.5/kernel/net
/lib/modules/3.13.5/kernel/net/802
/lib/modules/3.13.5/kernel/net/802/stp.ko
/lib/modules/3.13.5/kernel/net/llc
/lib/modules/3.13.5/kernel/net/llc/llc.ko
/lib/modules/3.13.5/kernel/net/ipv6
/lib/modules/3.13.5/kernel/net/ipv6/ipv6.ko
/lib/modules/3.13.5/kernel/net/wireless
/lib/modules/3.13.5/kernel/net/wireless/lib80211.ko
/lib/modules/3.13.5/kernel/net/bridge
/lib/modules/3.13.5/kernel/net/bridge/bridge.ko
/lib/modules/3.13.5/kernel/net/mac80211
/lib/modules/3.13.5/kernel/net/mac80211/mac80211.ko
/lib/modules/3.13.5/kernel/drivers
/lib/modules/3.13.5/kernel/drivers/net
/lib/modules/3.13.5/kernel/drivers/net/usb
/lib/modules/3.13.5/kernel/drivers/net/usb/cdc_subset.ko
/lib/modules/3.13.5/kernel/drivers/net/usb/cdc_eem.ko
/lib/modules/3.13.5/kernel/drivers/net/usb/rndis_host.ko
/lib/modules/3.13.5/kernel/drivers/net/usb/usbnet.ko
/lib/modules/3.13.5/kernel/drivers/net/usb/cdc_ether.ko
/lib/modules/3.13.5/kernel/drivers/net/usb/zaurus.ko
/lib/modules/3.13.5/kernel/drivers/net/tun.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath/ath9k
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath/ath9k/ath9k_common.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath/ath9k/ath9k_hw.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath/ath9k/ath9k_htc.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath/ath.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath/carl9170
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath/carl9170/carl9170.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/8192cu.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/hostap
/lib/modules/3.13.5/kernel/drivers/net/wireless/hostap/hostap.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/8812au.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/rtl818x
/lib/modules/3.13.5/kernel/drivers/net/wireless/rtl818x/rtl8187
/lib/modules/3.13.5/kernel/drivers/net/wireless/rtl818x/rtl8187/rtl8187.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/mt7601Usta.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/mt7650u_sta.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/zd1211rw
/lib/modules/3.13.5/kernel/drivers/net/wireless/zd1211rw/zd1211rw.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/rt2x00
/lib/modules/3.13.5/kernel/drivers/net/wireless/rt2x00/rt73usb.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/rt2x00/rt2x00usb.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/rt2x00/rt2800usb.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/rt2x00/rt2500usb.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/rt2x00/rt2x00lib.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/rt2x00/rt2800lib.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/8188eu.ko
/lib/modules/3.13.5/kernel/drivers/mtd
/lib/modules/3.13.5/kernel/drivers/mtd/nand
/lib/modules/3.13.5/kernel/drivers/mtd/nand/nandsim.ko
/lib/modules/3.13.5/kernel/drivers/usb
/lib/modules/3.13.5/kernel/drivers/usb/serial
/lib/modules/3.13.5/kernel/drivers/usb/serial/usbserial.ko
/lib/modules/3.13.5/kernel/drivers/usb/serial/cp210x.ko
/lib/modules/3.13.5/kernel/drivers/usb/serial/pl2303.ko
/lib/modules/3.13.5/kernel/drivers/usb/serial/ftdi_sio.ko
/lib/modules/3.13.5/kernel/drivers/misc
/lib/modules/3.13.5/kernel/drivers/misc/eeprom
/lib/modules/3.13.5/kernel/drivers/misc/eeprom/eeprom_93cx6.ko
/lib/modules/3.13.5/kernel/drivers/scsi
/lib/modules/3.13.5/kernel/drivers/scsi/sr_mod.ko
/lib/modules/3.13.5/kernel/drivers/cdrom
/lib/modules/3.13.5/kernel/drivers/cdrom/cdrom.ko
/lib/modules/3.13.5/kernel/drivers/media
/lib/modules/3.13.5/kernel/drivers/media/rc
/lib/modules/3.13.5/kernel/drivers/media/rc/bh-rc-core.ko
/lib/modules/3.13.5/kernel/drivers/media/i2c
/lib/modules/3.13.5/kernel/drivers/media/i2c/cx25840
/lib/modules/3.13.5/kernel/drivers/media/i2c/cx25840/cx25840.ko
/lib/modules/3.13.5/kernel/drivers/media/i2c/saa7115.ko
/lib/modules/3.13.5/kernel/drivers/media/i2c/msp3400.ko
/lib/modules/3.13.5/kernel/drivers/media/i2c/tvp5150.ko
/lib/modules/3.13.5/kernel/drivers/media/i2c/mt9v011.ko
/lib/modules/3.13.5/kernel/drivers/media/i2c/ir-kbd-i2c.ko
/lib/modules/3.13.5/kernel/drivers/media/i2c/wm8775.ko
/lib/modules/3.13.5/kernel/drivers/media/i2c/cs53l32a.ko
/lib/modules/3.13.5/kernel/drivers/media/pci
/lib/modules/3.13.5/kernel/drivers/media/pci/ttpci
/lib/modules/3.13.5/kernel/drivers/media/pci/ttpci/ttpci-eeprom.ko
/lib/modules/3.13.5/kernel/drivers/media/usb
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-dibusb-common.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-dw2102.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-cxusb.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-friio.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-af9005.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-dib0700.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-dibusb-mb.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-dibusb-mc.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-opera.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-gp8psk.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-dtv5100.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-digitv.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-ttusb2.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-a800.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-m920x.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-cinergyT2.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-vp7045.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-vp702x.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-nova-t-usb2.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-az6027.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-technisat-usb2.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-pctv452e.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-umt-010.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-dtt200u.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/b2c2
/lib/modules/3.13.5/kernel/drivers/media/usb/b2c2/b2c2-flexcop-usb.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/cx231xx
/lib/modules/3.13.5/kernel/drivers/media/usb/cx231xx/cx231xx.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/cx231xx/cx231xx-dvb.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/as102
/lib/modules/3.13.5/kernel/drivers/media/usb/as102/dvb-as102.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/siano
/lib/modules/3.13.5/kernel/drivers/media/usb/siano/smsusb.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/tm6000
/lib/modules/3.13.5/kernel/drivers/media/usb/tm6000/tm6000-dvb.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/tm6000/tm6000.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/au0828
/lib/modules/3.13.5/kernel/drivers/media/usb/au0828/au0828.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/bh_dvb_usb_v2.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/mxl111sf-tuner.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/mxl111sf-demod.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-mxl111sf.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-au6610.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-gl861.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-af9015.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-af9035.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-anysee.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-rtl28xxu.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-lmedm04.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-az6007.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb_usb_v2.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-ce6230.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-ec168.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/vuplus
/lib/modules/3.13.5/kernel/drivers/media/usb/vuplus/vuplus_tuner_turbo_driver.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/em28xx
/lib/modules/3.13.5/kernel/drivers/media/usb/em28xx/em28xx.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/em28xx/em28xx-dvb.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/videobuf-dvb.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/videobuf-vmalloc.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/bh-videodev.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/tuner.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/videobuf2-memops.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/bh-v4l2-common.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/videobuf2-vmalloc.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/v4l2-dv-timings.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/videobuf2-core.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/videobuf-core.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-core
/lib/modules/3.13.5/kernel/drivers/media/dvb-core/bh-dvb-core.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/m88ds3103.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/atbm8830.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/cxd2820r.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/ix2505v.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/ec100.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/lg2160.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/ves1x93.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/lnbp21.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/lnbp22.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/sp8870.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/mb86a16.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dib8000.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/si2165.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/si2168.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/bcm3510.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/sp887x.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/isl6405.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/isl6421.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/isl6423.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/mt312.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dibx000_common.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/s921.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/itd1000.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/mt352.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tda18271c2dd.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/or51132.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/or51211.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/zl10036.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/zl10039.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/l64781.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dib7000m.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dib7000p.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dvb-pll.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stv6110x.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tda10021.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tda10023.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tda10048.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/au8522_dig.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tda10071.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tda10086.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/as102_fe.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tda1004x.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stv0288.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stv0297.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stv0299.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/ds3000.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/m88rs2000.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/zl10353.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stv0367.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/si21xx.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/hd29l2.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/nxt200x.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/cx24110.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/cx24113.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/cx24116.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/cx24117.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/cx24123.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dib0070.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/s5h1409.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/s5h1411.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/au8522_common.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/s5h1420.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/a8293.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dib0090.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/s5h1432.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tua6100.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stb0899.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/mb86a20s.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stb6000.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/rtl2830.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/rtl2832.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/ts2020.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/ves1820.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/lgdt3305.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stb6100.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/cx22700.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/cx22702.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/af9013.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/af9033.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/lgdt330x.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dib9000.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tda8261.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/lgs8gl5.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stv0900.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tda826x.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stv090x.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/nxt6000.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dib3000mb.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dib3000mc.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stv6110.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tda665x.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/drxd.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/drxk.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/lgs8gxx.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners
/lib/modules/3.13.5/kernel/drivers/media/tuners/m88ts2022.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/mt20xx.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/fc2580.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/mxl5005s.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/mxl5007t.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tda18212.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tda18218.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tda18271.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tua9001.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/xc4000.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tuner-xc2028.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tuner-simple.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/max2165.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/mc44s803.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/r820t.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tea5761.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tea5767.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/e4000.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/qt1010.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/fc0011.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/fc0012.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/fc0013.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tda9887.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/mt2060.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/mt2063.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tuner-types.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tda8290.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/mt2131.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tda827x.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/xc5000.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/mt2266.ko
/lib/modules/3.13.5/kernel/drivers/media/common
/lib/modules/3.13.5/kernel/drivers/media/common/b2c2
/lib/modules/3.13.5/kernel/drivers/media/common/b2c2/b2c2-flexcop.ko
/lib/modules/3.13.5/kernel/drivers/media/common/cx2341x.ko
/lib/modules/3.13.5/kernel/drivers/media/common/cypress_firmware.ko
/lib/modules/3.13.5/kernel/drivers/media/common/tveeprom.ko
/lib/modules/3.13.5/kernel/drivers/media/common/bh_cypress_firmware.ko
/lib/modules/3.13.5/kernel/drivers/media/common/siano
/lib/modules/3.13.5/kernel/drivers/media/common/siano/smsmdtv.ko
/lib/modules/3.13.5/kernel/drivers/media/common/siano/smsdvb.ko
/lib/modules/3.13.5/kernel/drivers/staging
/lib/modules/3.13.5/kernel/drivers/staging/rtl8712
/lib/modules/3.13.5/kernel/drivers/staging/rtl8712/r8712u.ko
/lib/modules/3.13.5/kernel/drivers/staging/winbond
/lib/modules/3.13.5/kernel/drivers/staging/winbond/w35und.ko
/lib/modules/3.13.5/kernel/drivers/staging/wlan-ng
/lib/modules/3.13.5/kernel/drivers/staging/wlan-ng/prism2_usb.ko
/lib/modules/3.13.5/modules.dep
/lib/modules/3.13.5/extra
/lib/modules/3.13.5/extra/brcmfb.ko
/lib/modules/3.13.5/extra/fpga_directc.ko
/lib/modules/3.13.5/extra/dvb-bcm7362.ko
/lib/modules/3.13.5/extra/procmk.ko
/lib/modules/3.13.5/modules.dep.bin
/lib/modules/3.13.5/modules.devname
/lib/modules/3.13.5/modules.softdep
/lib/modules/3.13.5/modules.alias
/lib/modules/3.13.5/modules.order
/lib/modules/3.13.5/drivers
/lib/modules/3.13.5/drivers/net
/lib/modules/3.13.5/drivers/net/wireless
/lib/modules/3.13.5/drivers/net/wireless/rt5370sta.ko
/lib/modules/3.13.5/modules.alias.bin
DVB devices
/dev/dvb
/dev/dvb/adapter0
/dev/dvb/adapter0/ca3
/dev/dvb/adapter0/ca2
/dev/dvb/adapter0/ca1
/dev/dvb/adapter0/ca0
/dev/dvb/adapter0/frontend0
/dev/dvb/adapter0/audio0
/dev/dvb/adapter0/video0
/dev/dvb/adapter0/net4
/dev/dvb/adapter0/dvr4
/dev/dvb/adapter0/demux4
/dev/dvb/adapter0/net3
/dev/dvb/adapter0/dvr3
/dev/dvb/adapter0/demux3
/dev/dvb/adapter0/net2
/dev/dvb/adapter0/dvr2
/dev/dvb/adapter0/demux2
/dev/dvb/adapter0/net1
/dev/dvb/adapter0/dvr1
/dev/dvb/adapter0/demux1
/dev/dvb/adapter0/net0
/dev/dvb/adapter0/dvr0
/dev/dvb/adapter0/demux0
USBTuner revision
DVB Drivers revision
media-tree-module-a8293 - 0.0+git20140924-r0.29
media-tree-module-af9013 - 0.0+git20140924-r0.29
media-tree-module-af9033 - 0.0+git20140924-r0.29
media-tree-module-as102-fe - 0.0+git20140924-r0.29
media-tree-module-atbm8830 - 0.0+git20140924-r0.29
media-tree-module-au0828 - 0.0+git20140924-r0.29
media-tree-module-au8522-common - 0.0+git20140924-r0.29
media-tree-module-au8522-dig - 0.0+git20140924-r0.29
media-tree-module-b2c2-flexcop - 0.0+git20140924-r0.29
media-tree-module-b2c2-flexcop-usb - 0.0+git20140924-r0.29
media-tree-module-bcm3510 - 0.0+git20140924-r0.29
media-tree-module-bh-cypress-firmware - 0.0+git20140924-r0.29
media-tree-module-bh-dvb-core - 0.0+git20140924-r0.29
media-tree-module-bh-dvb-usb-v2 - 0.0+git20140924-r0.29
media-tree-module-bh-rc-core - 0.0+git20140924-r0.29
media-tree-module-bh-v4l2-common - 0.0+git20140924-r0.29
media-tree-module-bh-videodev - 0.0+git20140924-r0.29
media-tree-module-cs53l32a - 0.0+git20140924-r0.29
media-tree-module-cx22700 - 0.0+git20140924-r0.29
media-tree-module-cx22702 - 0.0+git20140924-r0.29
media-tree-module-cx231xx - 0.0+git20140924-r0.29
media-tree-module-cx231xx-dvb - 0.0+git20140924-r0.29
media-tree-module-cx2341x - 0.0+git20140924-r0.29
media-tree-module-cx24110 - 0.0+git20140924-r0.29
media-tree-module-cx24113 - 0.0+git20140924-r0.29
media-tree-module-cx24116 - 0.0+git20140924-r0.29
media-tree-module-cx24117 - 0.0+git20140924-r0.29
media-tree-module-cx24123 - 0.0+git20140924-r0.29
media-tree-module-cx25840 - 0.0+git20140924-r0.29
media-tree-module-cxd2820r - 0.0+git20140924-r0.29
media-tree-module-dib0070 - 0.0+git20140924-r0.29
media-tree-module-dib0090 - 0.0+git20140924-r0.29
media-tree-module-dib3000mb - 0.0+git20140924-r0.29
media-tree-module-dib3000mc - 0.0+git20140924-r0.29
media-tree-module-dib7000m - 0.0+git20140924-r0.29
media-tree-module-dib7000p - 0.0+git20140924-r0.29
media-tree-module-dib8000 - 0.0+git20140924-r0.29
media-tree-module-dib9000 - 0.0+git20140924-r0.29
media-tree-module-dibx000-common - 0.0+git20140924-r0.29
media-tree-module-drxd - 0.0+git20140924-r0.29
media-tree-module-drxk - 0.0+git20140924-r0.29
media-tree-module-ds3000 - 0.0+git20140924-r0.29
media-tree-module-dvb-as102 - 0.0+git20140924-r0.29
media-tree-module-dvb-pll - 0.0+git20140924-r0.29
media-tree-module-dvb-usb - 0.0+git20140924-r0.29
media-tree-module-dvb-usb-a800 - 0.0+git20140924-r0.29
media-tree-module-dvb-usb-af9005 - 0.0+git20140924-r0.29
media-tree-module-dvb-usb-af9015 - 0.0+git20140924-r0.29
media-tree-module-dvb-usb-af9035 - 0.0+git20140924-r0.29
media-tree-module-dvb-usb-anysee - 0.0+git20140924-r0.29
media-tree-module-dvb-usb-au6610 - 0.0+git20140924-r0.29
media-tree-module-dvb-usb-az6007 - 0.0+git20140924-r0.29
media-tree-module-dvb-usb-az6027 - 0.0+git20140924-r0.29
media-tree-module-dvb-usb-ce6230 - 0.0+git20140924-r0.29
media-tree-module-dvb-usb-cinergyt2 - 0.0+git20140924-r0.29
media-tree-module-dvb-usb-cxusb - 0.0+git20140924-r0.29
media-tree-module-dvb-usb-dib0700 - 0.0+git20140924-r0.29
media-tree-module-dvb-usb-dibusb-common - 0.0+git20140924-r0.29
media-tree-module-dvb-usb-dibusb-mb - 0.0+git20140924-r0.29
media-tree-module-dvb-usb-dibusb-mc - 0.0+git20140924-r0.29
media-tree-module-dvb-usb-digitv - 0.0+git20140924-r0.29
media-tree-module-dvb-usb-dtt200u - 0.0+git20140924-r0.29
media-tree-module-dvb-usb-dtv5100 - 0.0+git20140924-r0.29
media-tree-module-dvb-usb-dw2102 - 0.0+git20140924-r0.29
media-tree-module-dvb-usb-ec168 - 0.0+git20140924-r0.29
media-tree-module-dvb-usb-friio - 0.0+git20140924-r0.29
media-tree-module-dvb-usb-gl861 - 0.0+git20140924-r0.29
media-tree-module-dvb-usb-gp8psk - 0.0+git20140924-r0.29
media-tree-module-dvb-usb-lmedm04 - 0.0+git20140924-r0.29
media-tree-module-dvb-usb-m920x - 0.0+git20140924-r0.29
media-tree-module-dvb-usb-mxl111sf - 0.0+git20140924-r0.29
media-tree-module-dvb-usb-nova-t-usb2 - 0.0+git20140924-r0.29
media-tree-module-dvb-usb-opera - 0.0+git20140924-r0.29
media-tree-module-dvb-usb-pctv452e - 0.0+git20140924-r0.29
media-tree-module-dvb-usb-rtl28xxu - 0.0+git20140924-r0.29
media-tree-module-dvb-usb-technisat-usb2 - 0.0+git20140924-r0.29
media-tree-module-dvb-usb-ttusb2 - 0.0+git20140924-r0.29
media-tree-module-dvb-usb-umt-010 - 0.0+git20140924-r0.29
media-tree-module-dvb-usb-vp702x - 0.0+git20140924-r0.29
media-tree-module-dvb-usb-vp7045 - 0.0+git20140924-r0.29
media-tree-module-e4000 - 0.0+git20140924-r0.29
media-tree-module-ec100 - 0.0+git20140924-r0.29
media-tree-module-em28xx - 0.0+git20140924-r0.29
media-tree-module-em28xx-dvb - 0.0+git20140924-r0.29
media-tree-module-fc0011 - 0.0+git20140924-r0.29
media-tree-module-fc0012 - 0.0+git20140924-r0.29
media-tree-module-fc0013 - 0.0+git20140924-r0.29
media-tree-module-fc2580 - 0.0+git20140924-r0.29
media-tree-module-hd29l2 - 0.0+git20140924-r0.29
media-tree-module-ir-kbd-i2c - 0.0+git20140924-r0.29
media-tree-module-isl6405 - 0.0+git20140924-r0.29
media-tree-module-isl6421 - 0.0+git20140924-r0.29
media-tree-module-isl6423 - 0.0+git20140924-r0.29
media-tree-module-itd1000 - 0.0+git20140924-r0.29
media-tree-module-ix2505v - 0.0+git20140924-r0.29
media-tree-module-l64781 - 0.0+git20140924-r0.29
media-tree-module-lg2160 - 0.0+git20140924-r0.29
media-tree-module-lgdt3305 - 0.0+git20140924-r0.29
media-tree-module-lgdt330x - 0.0+git20140924-r0.29
media-tree-module-lgs8gl5 - 0.0+git20140924-r0.29
media-tree-module-lgs8gxx - 0.0+git20140924-r0.29
media-tree-module-lnbp21 - 0.0+git20140924-r0.29
media-tree-module-lnbp22 - 0.0+git20140924-r0.29
media-tree-module-m88ds3103 - 0.0+git20140924-r0.29
media-tree-module-m88rs2000 - 0.0+git20140924-r0.29
media-tree-module-m88ts2022 - 0.0+git20140924-r0.29
media-tree-module-max2165 - 0.0+git20140924-r0.29
media-tree-module-mb86a16 - 0.0+git20140924-r0.29
media-tree-module-mb86a20s - 0.0+git20140924-r0.29
media-tree-module-mc44s803 - 0.0+git20140924-r0.29
media-tree-module-msp3400 - 0.0+git20140924-r0.29
media-tree-module-mt2060 - 0.0+git20140924-r0.29
media-tree-module-mt2063 - 0.0+git20140924-r0.29
media-tree-module-mt20xx - 0.0+git20140924-r0.29
media-tree-module-mt2131 - 0.0+git20140924-r0.29
media-tree-module-mt2266 - 0.0+git20140924-r0.29
media-tree-module-mt312 - 0.0+git20140924-r0.29
media-tree-module-mt352 - 0.0+git20140924-r0.29
media-tree-module-mt9v011 - 0.0+git20140924-r0.29
media-tree-module-mxl111sf-demod - 0.0+git20140924-r0.29
media-tree-module-mxl111sf-tuner - 0.0+git20140924-r0.29
media-tree-module-mxl5005s - 0.0+git20140924-r0.29
media-tree-module-mxl5007t - 0.0+git20140924-r0.29
media-tree-module-nxt200x - 0.0+git20140924-r0.29
media-tree-module-nxt6000 - 0.0+git20140924-r0.29
media-tree-module-or51132 - 0.0+git20140924-r0.29
media-tree-module-or51211 - 0.0+git20140924-r0.29
media-tree-module-qt1010 - 0.0+git20140924-r0.29
media-tree-module-r820t - 0.0+git20140924-r0.29
media-tree-module-rtl2830 - 0.0+git20140924-r0.29
media-tree-module-rtl2832 - 0.0+git20140924-r0.29
media-tree-module-s5h1409 - 0.0+git20140924-r0.29
media-tree-module-s5h1411 - 0.0+git20140924-r0.29
media-tree-module-s5h1420 - 0.0+git20140924-r0.29
media-tree-module-s5h1432 - 0.0+git20140924-r0.29
media-tree-module-s921 - 0.0+git20140924-r0.29
media-tree-module-saa7115 - 0.0+git20140924-r0.29
media-tree-module-si2165 - 0.0+git20140924-r0.29
media-tree-module-si2168 - 0.0+git20140924-r0.29
media-tree-module-si21xx - 0.0+git20140924-r0.29
media-tree-module-smsdvb - 0.0+git20140924-r0.29
media-tree-module-smsmdtv - 0.0+git20140924-r0.29
media-tree-module-smsusb - 0.0+git20140924-r0.29
media-tree-module-sp8870 - 0.0+git20140924-r0.29
media-tree-module-sp887x - 0.0+git20140924-r0.29
media-tree-module-stb0899 - 0.0+git20140924-r0.29
media-tree-module-stb6000 - 0.0+git20140924-r0.29
media-tree-module-stb6100 - 0.0+git20140924-r0.29
media-tree-module-stv0288 - 0.0+git20140924-r0.29
media-tree-module-stv0297 - 0.0+git20140924-r0.29
media-tree-module-stv0299 - 0.0+git20140924-r0.29
media-tree-module-stv0367 - 0.0+git20140924-r0.29
media-tree-module-stv0900 - 0.0+git20140924-r0.29
media-tree-module-stv090x - 0.0+git20140924-r0.29
media-tree-module-stv6110 - 0.0+git20140924-r0.29
media-tree-module-stv6110x - 0.0+git20140924-r0.29
media-tree-module-tda10021 - 0.0+git20140924-r0.29
media-tree-module-tda10023 - 0.0+git20140924-r0.29
media-tree-module-tda10048 - 0.0+git20140924-r0.29
media-tree-module-tda1004x - 0.0+git20140924-r0.29
media-tree-module-tda10071 - 0.0+git20140924-r0.29
media-tree-module-tda10086 - 0.0+git20140924-r0.29
media-tree-module-tda18212 - 0.0+git20140924-r0.29
media-tree-module-tda18218 - 0.0+git20140924-r0.29
media-tree-module-tda18271 - 0.0+git20140924-r0.29
media-tree-module-tda18271c2dd - 0.0+git20140924-r0.29
media-tree-module-tda665x - 0.0+git20140924-r0.29
media-tree-module-tda8261 - 0.0+git20140924-r0.29
media-tree-module-tda826x - 0.0+git20140924-r0.29
media-tree-module-tda827x - 0.0+git20140924-r0.29
media-tree-module-tda8290 - 0.0+git20140924-r0.29
media-tree-module-tda9887 - 0.0+git20140924-r0.29
media-tree-module-tea5761 - 0.0+git20140924-r0.29
media-tree-module-tea5767 - 0.0+git20140924-r0.29
media-tree-module-tm6000 - 0.0+git20140924-r0.29
media-tree-module-tm6000-dvb - 0.0+git20140924-r0.29
media-tree-module-ts2020 - 0.0+git20140924-r0.29
media-tree-module-ttpci-eeprom - 0.0+git20140924-r0.29
media-tree-module-tua6100 - 0.0+git20140924-r0.29
media-tree-module-tua9001 - 0.0+git20140924-r0.29
media-tree-module-tuner - 0.0+git20140924-r0.29
media-tree-module-tuner-simple - 0.0+git20140924-r0.29
media-tree-module-tuner-types - 0.0+git20140924-r0.29
media-tree-module-tuner-xc2028 - 0.0+git20140924-r0.29
media-tree-module-tveeprom - 0.0+git20140924-r0.29
media-tree-module-tvp5150 - 0.0+git20140924-r0.29
media-tree-module-v4l2-dv-timings - 0.0+git20140924-r0.29
media-tree-module-ves1820 - 0.0+git20140924-r0.29
media-tree-module-ves1x93 - 0.0+git20140924-r0.29
media-tree-module-videobuf-core - 0.0+git20140924-r0.29
media-tree-module-videobuf-dvb - 0.0+git20140924-r0.29
media-tree-module-videobuf-vmalloc - 0.0+git20140924-r0.29
media-tree-module-videobuf2-core - 0.0+git20140924-r0.29
media-tree-module-videobuf2-memops - 0.0+git20140924-r0.29
media-tree-module-videobuf2-vmalloc - 0.0+git20140924-r0.29
media-tree-module-wm8775 - 0.0+git20140924-r0.29
media-tree-module-xc4000 - 0.0+git20140924-r0.29
media-tree-module-xc5000 - 0.0+git20140924-r0.29
media-tree-module-zl10036 - 0.0+git20140924-r0.29
media-tree-module-zl10039 - 0.0+git20140924-r0.29
media-tree-module-zl10353 - 0.0+git20140924-r0.29
Vu+ Kernel Drivers
-rw-r--r-- 1 root root 5764 Dec 11 2018 /lib/modules/3.13.5/extra/brcmfb.ko
-rw-r--r-- 1 root root 7403664 Dec 11 2018 /lib/modules/3.13.5/extra/dvb-bcm7362.ko
-rw-r--r-- 1 root root 2376 Dec 11 2018 /lib/modules/3.13.5/extra/fpga_directc.ko
-rw-r--r-- 1 root root 4412 Dec 11 2018 /lib/modules/3.13.5/extra/procmk.ko
