Black Hole 3.0.9.F Vu+ Zero & Vu+ Zero Rev.2.0
Hello, I have installed this new version 3.0.9 F and it seems that when you install a list of channels that in version 3.0.5 do not like anything and do not detect or raise the target, on another occasion when uploading it with dreamst it is restarting in loop. I have to say that in this it seems that he only likes version 3.0.9 other versions do not start. Has it ever happened to you?
The zero rev. 2 is not compatible with older bh versions because of chipset change.
Anyone know how to tell me the username and password of this image for telnet?
for DCC-2E tool , I use
user : root
password : dreambox
from the browser //http:root@BM750/
Will take to the openWebif
It's important to say that every images downloaded from this website has got no password: if any tools need a password it's their responsibility and their choice.
If you downloaded a backup or an installer from an unofficial BH/OBH website, it's another story....
This is a clean install, nothing else is installed.
epgimport.xz is downloaded to /tmp but nothing else happens.
Have tested OpenBH and where everything worked very well, this one has a much newer version of epg import.
You are missing the conf file /etc/enigma2/epgimport.conf
You need to open EPG settings in Blackhole and setup your EPG Import where the epg.dat file is stored
Save your settings and restart enigma2 and all should work just fine.
But with Blackhole i strongley recommend the use of CrossEPG :)
Cannot use crossepg for iptv epg along with custom.channels.xml
Stored for only Norwegian epg source and gets the file:
epgimport.conf in /etc/enigma2/
Manual download doesn't work any better now.
On my Zero4K this is plug and play.
This is not the case at regular zero.
You are correct that CrossEPG does not work as easy as EPG Import when it comes to custom sources
But how do you add your custom source to EPG Import??
Regarding iptv epg, how this is set up is not the problem.
The file is created together with m3u downloaded with script to /etc/epgimport/ own source is also added rytec.sources.xml
After all, epg import should work even without my files but does not.
So lets start form the beginning ;)
Does your EPG importer crash for all sources?
If you de select your custom source it still crash?
Or cant you even open the source page with blue button?
Black Hole 3.0.9.F​
What is new ?
  • Add support for Vu+ Zero Rev.2.0
***** This image is needed if you have the new Vu+ Zero Rev.2.0, you can not use an older BH image with the new Vu+ Zero Rev.2.0 *****​
1-png.44697
2-jpg.44718
4-jpg.44700
5-jpg.44701
6-jpg.44690
8-jpg.44692
9-jpg.44693
10-jpg.44694
11-jpg.44695
12-jpg.44696
This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash.
This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
- Integrated OpenEpg
- CrossEPG supported
- EPG Import supported
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
ServiceApp and Exteplayer3 are both external plugins, and are not part of the BH image, therefore any users that do not want / need to use these plugins, can remove them via the BH SpeedUp panel.
Credits:
Thanks to MX3L for ServiceApp https://github.com/mx3L/serviceapp/tree/develop
Thanks to SamSamSam for Exteplayer3 https://github.com/e2iplayer/exteplayer3
Thanks to dpeddi for patching ServiceApp and Exteplayer3 to work on BH.
Thanks to Pedro_Newbie for Backup script.
DISCLAIMER
LICENSE (TERM OF USE)
thanks a lot!
i have a question. i have vu zero and the lastest version blackhole. can i see vu zero with zerotier? and if i install zerotier its posible see out red?
