Black Hole 3.0.9 Multistream Vu+ Ultimo4K
First thanks for this beautiful image.
I have VU+ Ultimo 4K and I updated it to 3.0.9 by USB then by addon panel online.
It has a twin FCC tuner and one single DVBS2 tuner for blind scan only.
I disconnected all cables from FCC tuner and I made a blind scan on single tuner.
All available transponders found and also channels are showing perfectly.
But when I change cable from single tuner and connect it to twin FCC tuner (after turning off receiver completely by removing power socket and with its LED off), and then I configure FCC tuner setup correctly in the setting menu (I changed single tuner to no connected), some transponders have no signal (0) but some of others have (Full HD).
When I connect the cable back to the single tuner (with proper configuration in the setting menu), I can see those channels correctly. I think my tuners are OK, but why this is happening??
I found my answer:
When doing blind scan, no transponder will be stored in satellites.xml file.
I used dreamset program to add them manually.
Congratulations for the new release :)
i just would like to report an issue happened with me after the setup
The Wifi Network did not want to connect !!!! i tried the image too many times and for sure fresh clean install, but still it did not connect to the wifi network
all the other images 3.0.8, OBH and the non BH images works like charm, but the new release here does not work...
any suggestions?
I have the same problem After upgrading from 3.0.5 to 3.0.9 my Wi-Fi configuration doesn’t work
You have update BH 3.0.9 online after image flash ??
Sorry Matrix10 I don't understand what you mean, I just downloaded the image and instal it as usually in my Vu+ Ultimo but now I'm in the phase of configuration but the wifi doesn't work. thanks for reply
After installation, image update should be made online.
If you do not have a wifi then wired.
Online update
Green button>>yellow>>Online BH image update.
After update config and test Wifi again.
Do not forget to use only letters and numbers in passwords
Some routers have problems with some symbols
Online update
How can I update online if I don't have internet?
