Black Hole speed up Error installing extensions
José Andrés
when trying to activate plugin in some black hole speed up, but it is not possible because package fails says "unknown package enigma-plugin-extensions .."
opkg_install_cmd "Can not install package .."
Even when I uninstall a package already installed on the image and I want to install the error continues
angelofsky1980
BlackHole Driver Specialist
You need internet connection to enable/install packages via BH SpeedUp panel.
