lorenzo64
BlackHole Vu+ Duo v. 1.5.1
MULTIBOOT - MULTITUNER - EPGPLUS
This Release Includes:
-Vu+ drivers: 20110426
Fix timeshift problem
-New Skin Matrix10 Black & White SE
- Double Epg system (Black Hole native epg and Crossepg plugin)
- Update E2 and Plugins
- Update OE tree
- Fix Fancontrol plugin problem
- Reduce booting time(about 15 percent).
- Enhance overall NAND performance.
- For other details, please take a loot at git log.
- Fix LPCM Sound problem in vob and media playback
- Fix EOS detection problem in media playback
- Fix some CI modules recognition problem
- Reduce booting time(Needs a image update)
- Change SRC_URI of driver
For M7 P r e m i u m epg: menu -> setup -> crossEpg -> Scripts providers - MEDIAPREM -> Download
Crossepg is a is a lightweight and portable epg for enigma2 dvb receivers (sat, cable and dtt). (c) 2009-2010 Sandro Cavazzoni: http://www.crossepg.com
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Time Shift
Button Red = Start Record
Addons
Infobar / OSD
Analog Clock Enigma2
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Manager Kernel Modules (Kernel module operator)
Black Hole Mount Wizard (Mount points)
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
Usb Tuner Panel
Info Panel
1 - E2 Setting (Enigma2 configurations)
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Credits
Thanks to Sandro Cavazzoni for Cross EPG
Thanks to bigroma (vuplus-community board) for rt3070 patches.
DISCLAIMER
THE BLACK HOLE IMAGE IS BASED ON THE OFFICIAL FIRMWARE PULBISHED BY VU+ AND IN ACCORDANCE WITH THE LAW IT CONTAINS ONLY SYSTEM ADDITIONS & GRAPHIC CHANGES.
LASTLY, THE BLACK HOLE IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR IILEGAL PURPOSES SUCH AS CARD SHARING.
LICENSE (TERM OF USE)
ANY CHANGES OR ADDITIONS TO BLACK HOLE IMAGE THAT INVOLVE UNLAWFUL USE OF THE IMAGE SUCH AS CARD-SHARING AND EMULATORS ARE NOT ALLOWED AND CAUSE THE REWOKE OF THIS LICENSE.
