Black Hole Vu+ Duo 1.7.3 (Skin Tribute)
Yes, but looptrought is not for signal to second receiver but to intern second tuner. .
As far as I know this option does not exist for second receiver .
wow this usb format wizard works not as intended,, i know you guys have worked hard on images and u did a great job but i can't format my usb and cross epg downloads 0 bytes data files so epg dont work either, no probs on 1.72 image
crossepg not working all database files is o bytes of data and when you update the epg you get black screen, time to go back to 1.72
If the box detects the USB stick
even you do not have to make any format but only mount with Devices Manager
to work with crossEPG
If you like to use USB stick for Image multiboot with Meoboot you have to format
USB stick.
For CrossEPG,Picons etc you can use FAT32 formated USB stick but you must mount in Devices manager.
So something is wrong
you have not make mount
A write-protected USB
or USB does not work well with V U+
and in CrossEPG you have to
1.config storage device >> USB Stick
2.Update providers
3.Download EPG
"Channel number in osd"!!
Finally you have prepared what I was waiting for months!I hope to see more skins with this feature!Thank you very much!
Hey,
I like to use BH - Images on my UNO, but since meoboot I have a problem with WLAN. Every Image (for example sifteam image or open AAF) I installed with Meoboot; when I boot this image there will be no WLAN. The Stick can`t be started and while scanning for my FRITZ!BOX the UNO crashed. This is only by the images in meoboot, in flash the BH (1.7.3) there are no problems. The same wasalso by 1.7.2. Has anyone an idea what it could be?
Thanks for replies
Hey,
Thanks for replies
The difference in the images in a flash and USB
We do not have perfect multiboot nor are we ever had.
Does it mean that I never can be online with image installed on multiboot ?
Sorry I just saw that I´ve posted in wrong section because I have VU+ UNO, hope this is no problem
That I do not know. Because I do not use permanent Wlan depending on whether you have support for WLAN or not in all images.
I use a network with a wire and I do not have these problems
and I can use almost all images.
But to be honest I do not use these images
but I only use BH images .
Who uses a longer period BH images knows why this is so .
Yeah that`s right, but the problems even be there when I install the same BH on multiboot- BH in the flash good, BH on multiboot bad
