Black Hole Vu+ Duo 1.7.4 Parallel Universes
hi
when i want to setup ***** by blue panel it say ;sorry wrong image in flash found you have to install in flash blackhole image v.1.7.4. it s not on multi boot;what is wrong?
Great work Blackhole Team.
Want to try this out guys but as I understand there is no solution for those of us who use multiquick button?
Thanks.
Hi to all,i have just 1 problem on thise image with thise plugins : Stream Tv Player (IPTV RTSP/RTMP protocols)
i tourn on thise plugin and i chose kanal 5 i picture is freez but sound go,i cant whatch any chanels from list,allways picture frezz but sound of chanels normaly worke,what is problem?do i need to open some new port in my router?
Got a problem here guys, any help appreciated.
When I press Red to enter Universe my box starts to rewind. If I take the USB out I get the message I need a dedicated USB and instructions. But as soon as I put the USB back in and press red the vu duo starts to rewind again.
I have moved the USB to other USB ports but the same issue happens, I have swapped for another USB but still the same issue happens.
I have installed the multiquick buttin that was created for 1.74 so I dont know if thats causing the problem or not.
Also my Vu Duo cant see the USB to format but yet it can see the chip mounted and I can use the chip ok for other stuff.
Any ideas?
Many thanks.
Any ideas?
Many thanks.
I suggest to DO NOT USE ABSOLUTELY Multiquickbutton plugin or other similar plugins.
first of all thanks BlackHole team for this excelent image.
all work fine with just one usb stick ( two partitions one for epg swap and picons and the other for /universe ) and Multiquickbutton 1.74 .
but i have a little problem with epg , when jumping to an other universe the epg does'nt load so i set force epg reload on boot on crossepg wich resolved the issue partially but EIT epg already "downloaded "does'nt reload.
When i installed all, duo keep starting on display...i need to update something before flashing to this image ?
-What image U had on Duo , and did U update the boot loader CFE?
-Then use a quick (erase) format on the USB , before U extract the BH image directly into the USB!
And as MX10 sys all usb have to be removed , after upgrade!
