Black Hole Vu+ Duo 1.7.6
IMDB
It's more a question for the plugin author ..
has nothing to do with image.
As far as I know the problem with this plugin exists in all images.
IMDB
Informations about movies(from IMDB) can see in DDamir subtitle player too. Plugin can be downloaded from our addons server.
Do you know how much work is an adaptation of skins ??
or you think that they coming out of machine :D
For 48 hours we have make 14 skins available.
We have added more than five entirely new panels
and we have test all this.
Could you list what 14 skins are currently available please? :)
you can see all skins for BH 1.7.6 on our image server
Green>>Yellow>>Addons Download Manager>>Black Hole Image skins
Thanks mate, I relaize that.
But that's after you've already installed the image.
Was just trying to weigh up whether to upgrade from 1.7.5 or not.
i understand that, but i think a small team should be assembled to work on the code changes for the old skins to work, i know it does take time for that but when they are done more people would be even more pleased.
Hi,
Hope you can help.
I am having problems loading 1.7.6. VU box will not read the usb, I have never had this problem when loading previous images.
I have also trid a different usb stick without success.
I would be grateful for any advice.
Regards,
John
Hi,
Hope you can help.
Regards,
John
Remove all usb sticks from the box, and try with just the usb you are using to update your box.
We all respect your effort :notworthy: , by the way could you please add my favourite Skin : Army NextGen Gradient HD 1.7.6 Thanx in advance...
