lorenzo64
Black Hole 2.0.2 - Meoboot Revenge
NEW NEW NEW meoboot v2.0:
Meoboot has been completely recoded in order to:
Keep cpu usage to 0%
To be compatible with all OE 2.0 Vu+ images.
You can use meoboot for multiboot, to test any other OE 2 image, for example:
VTI
OpenAAF
OpenPLI
OpenSIF
OpenSPA
OpenViX
and so on...
You can also use meoboot to expand your flash.
For example install the latest Black Hole image in flash,
then install meoboot on a usb stick (i.e 4gb)
Now install again the same Black Hole image in meoboot.
Boot the Black Hole image installed in multiboot and you will have
4gb of flash space.
Black Hole 2.0.2 Changes and updates:
- remove sctzap dvbtraffic.
- Add new recipe e2openbhplugins
- python: add python-beautifulsoup and python-dnspython
- enigma2 add dependencies for ondemand plugin
- r8192cu Added some devices to driver:
- [wlan] added more options to RT5572 driver
- [autoshutdown] adapted default time patch.
- Online Feeds Settings: Now listed in alphabetical order
- Bhsettings adjusted: meoboot device in device panels
- Change device mount system to UUID=
- Components/Harddisk: fix bug in hdd inizialization
- picload: updates and optimizations ...
- skin.py: make skin compatible with Openpli relative coordinates
- Update translations: Estonian, Polish, French and Greek
- [streamplayer] enhanced player and updated stream list.
- NetworkSetup: added manual-nameserver settings
QUI
