Black Hole Vu+ Duo 2.0.2 Rev. A
I did an software update using the BH online feed. There were 34 packages downloded and installed. The software info for my box now tells me that I am running 2.0.2 Rev B
One more thing. I am willing to help to translate to the Swedish language, since there is lack of translation for the Swedish language in the BH image.
I have not find any instructions concerning translation. Can someone point out where I can find those instructions?
In this Board there is an entire section regarding translations: http://www.vuplus-community.net/board/forums/black-hole-translations.72/
Guys 1st thx for the update, box is really faster but i have some troubles.
In start i wanna say that in the very 1st versions of BH when meoboot is introduced i was using it and i had all the previus versions installed in my stick.
1st problem is that when i installed 2.0.2 and i went to say install meoboot in the same stick IT DELETED all my previus installs with no reason, i dont get it why this huppent and if you can fix it this will be very good. For this reason i wanna say to people that have images in usb stick with the previus meoboot to DONT INSTALL Meoboot to the same stick till a solution is found.
2nd problem that i experience is the MountPoints in BH Device Manager.
I did this as what i do always a long time now. I install the latest version in flash, i did update with Software Management and then i config In Devices manager my Internal HDD in /media/hdd and Usb in /media/usb, after i installed meoboot in usb i puted the firmware in meoboot upload i installed 2.0.2 in meoboot, i did rst , i booted with 2.0.2 from usb , i did again update and i went to Devices Manager and i reconfigured again the mountpoints.
Here is the strange part, after the reboot and start again from Usb the device mounting went in the opposite allone without my fault and i am pretty sure in this. Now i have my HDD as /media/usb and my usb as /media/hdd. No matter if i try to changed them again when i go to Mountpoints i see BOTH devices saying that are mounted as MEOBOOT with NO ability to change them. Same huppens even if i boot from flash also.
I dont know if this is a bug but i need a way to change them. As test i deleted everything and i did the same procedure all over and same huppened.
If you can tell me the file in the system that is responsible of this setting i want to know it to change the mountpoints mannually.
Thx
Chris
Edit: There is one possibility of a mistake of my side. I might installed the latest meoboot NOT in usb stick but in HDD. Im trying to figure it out.
Forget everything i said guys and sorry. By mistake i installed meoboot in HDD :wallbash: and all my problems raised after this...
Are we sure it's down to meoboot?
As I've tried 2 different hard drives and maybe a dozen or so flavours of BH 2.0 and each of them won't run the other properly.
Well, OK, the images realise a HDD is present but don't show my existing recorded files. In my openwebif details, the hdd shows up as 500 GB, but with - 1mb space free?
The only solution I have found is to do a hdd check under bh setup - > harddisk - etc and let it run. Somehow it does reset itself so to speak and my videos show up under recorded files.
It is getting rather annoying though. Any time I have to turn off my duo, or reboot it (when crossepg messes up) I have to rescan the hdd to get my files back and be able to record again.
I was on BH1.76 and everything was going great.
Thought with all the great functions now available in BH2.0 that I should upgrade.
Guys I have a problem, after upgrading to 2.0.2 my box shutdown randomly. In 2 days it went down twice.... What's going on???? I put the box in standby and, after some hours, when I try to switch it on, I see that it's restarting just like a shutdown happened! If I put the box in standby and I switch it on in few minutes no problem.
Pls help
Since i see too many people brake their heads with this new AutoShutdown feature i wanna ask if it is possible in future updates this feature to be default OFF and if a user wants can enable it.... just a thought.
after latest online update to 2.0.2.c
my box sometimes dont Wake up after going to standby ,,,only red led shows,, have to hard reset the stb on switch at the backside...???
