Black Hole Vu+ Duo 2.0.2 Rev. D
Why is blackhole images becoming a disaster?/// every time i upgrade a new problem appears..its madness///is someone skimming too much off the top or smoking some weird shit or something...mytube player problems now....cant type in in what i want to see????...last release was permanent timeshift problems/b4 that i forget what was fucked up...what is the script here?????????????????????
if you can not make a good update
install image again.
Work from,MyTube depends not only on image
but primarily from the MyTube plugin and net.
Ok, it did work, but then I have to take a new scan and then make a new favorite list.
Difrent setting have difrent name of satellite.
I think when you setup good your satelite and reboot gui your old seting will be work .
Best good way is made when you have all setup good made personal backup.
After this when you will be have problem is easy restored backup.
-my friends.. im wrote this lines with full of respect ,not as complaining... but..
-After loooomg time i change from 179 to 202-- after loong suffering with continous green, swap, making universe to free memory etc etc.. i faced with the one small stupid problem in utube.. CANT fast forward with the numers 3 6 9 and 147... the image works good, picture ok.. but WHY this small issue cannot be fixed, what works nice in prevoius versions..
-Guys, begging you.. is it only my problem? i downgrade from 201 months vefore to 179 becouse of this silly things... now its continues..
thanks.
thanks.
Did you try to check your skip time settings in Customize menu?
Menu > Setup > System > Customize > Select Setup Mode: Expert ···· Custom Skip Time...
RO Yes, i did... Same as ith 179 as always, simply the ff or rew is not in function, the red square is come out as information, did you or somebody tryed my issue?
I just tried it with Ultimo and Solo2 and I have not any problem.
Did you install any plugin to manage your recordings?
I am unable to backup personal settings. Green screen every time I try. In fact I have never encountered so many green screens before. I just tried to update software through the machine and it has done it again. but it doesn't just reset . very frustrating at the moment
