Black Hole Vu+ Duo 2.0.5 galaxy
Hello, thanks for this very good image.
I have one problem with this image: when I record a movie timed, and I play the recorded movie, option for choosing subtitles doesn't work...(or it is disable) the movie has had the subtitles.
As I have previous use OpenPli image, and there I didn't have this problem, you can chose during playback, to enable or disable the subtitles.
Interesting is that this works perfect in Blackhole 2.0.5 in Vu+Solo, why is not working in Duo version?
This is very important for me and I wold be very pleased and ready to help to fix this problem.
Yes, I agree, should be easy to fix... OR? ;)
Press yellow button> yellow button during playback. Takes you to subtitle menu working on my duo
Black Hole 2.0.5 galaxy​
"The Black Hole is expanding in our galaxy.
We need more space..."
Starting from this version, the Black Hole image will fully support an internal hdd larger than 2 TB.
The new initialise function will partition your hdd with optimal alignment and will format it in the linux ext4 filesystem, which will give the best performance.
Warning: Duo2 requires a Cfe upgrade to V2 before you flash this image.
Main changes:
  • New Support hdd larger than 2TB
  • New Subtitle customisation
    • Ttx subtitle font size
    • subtitle delay when timing lags
    • subtitle delay when timing is bad
    • yellow Dvb subtitles
    • centered Dvb subtitles
    • Dvb subtitles black transparency
  • New support for coldboot "Wake on Lan" (Duo2)
  • New firmware upgrade option for Vfd controller and Front Processor (Duo2)
  • New hotkey for Subtitle window: (2x Yellow button)
Vu+ Drivers updates (duo2):
  • Fix WOL problem
  • Add proc entry for WOL
  • Fix loop-through problem when 2 dual tuners are installed
  • Improve VFD controller update(VFD controller update will resolve remote control sensitivity issue)
  • Fix Play/Pause key problem
  • Support FP update
  • Support VFD controller update
  • Fix recording problem
  • Fix no audio in radio channels
Misc:
  • Add Tools/Alternatives
  • Add WOLSetup (WakeOnLan) plugin (Duo2)
  • Add parted tool to partion and format internal Hdd
  • Switch to parted and ext4 in hdd inizailise function
  • Change module description from RT2870 to RT3070/3370/5370/5372 and fixed module installation in the correct place
  • Add patches for RT3070 ralink driver
  • Fix rt5572 driver
  • Add some devices not yet included into rt5572 supports
  • Add web-manual Duo2
  • [HbbTV] fix rtl auth problem
  • Add fuse-module and fuse-utils for ntfs-3g
  • [Kernel] Solo2 & Duo2: Add Nls modules for other charsets
  • [Kernel] Fix flash_erase option on postinst
  • [Dvbmediasink] Fix switching between aac and other codecs
  • [Gst-plugins-bad] Update SRCREV & patches
  • Add checkvfd package
  • Added new driver mt7610u (802.11a/b/g/n/ac support)
  • Update languages cs, da, fr, sk, sv.
The image MUST be installed in flash.
Black Hole does not support images not installed in flash.​
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons​
Infobar / OSD​
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel​
Addons (added)
Online Feeds Settings update
Red Panel
Black Hole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
THE BLACK HOLE IMAGE IS BASED ON THE OFFICIAL FIRMWARE PUBLISHED BY VU+ AND IN ACCORDANCE WITH THE LAW IT CONTAINS ONLY SYSTEM ADDITIONS & GRAPHIC CHANGES.​
LASTLY, THE BLACK HOLE IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.​
LICENSE (TERM OF USE)​
many thanks
