Black Hole Vu+ Duo 2.1.0.1
Black Hole 2.1.0.1
What is new?
    • Teletext: Fixed and Updated (thanks to dpeddi)
    • OpenWebIf: Fixed and updated
    • BhFastEpg: Fixed
    • [hbbtv/youtubetv] Fixed hanup bug and segmentation fault
    • tuxtxt: implement handlePressedKey and handleKey
    • tuxtxt: handling to keymap.xml
    • Support soloSE on text input.
    • Support soloSE on some plugin.
    • [videomode] enabled Scart for soloSE
    • [HDMICEC, Transcoding] fix for soloSE
    • [videomode] support soloSE
    • [FactoryTest] cleanup and remove
Online update available.
Can not flah duo2 after OPli4 with BH 2.1.0.1. Am I doing something wrong?
Verify all necessary conditions (pendrive format, zipfile corruption and backup presence into HDD). Remove also ALL other USB devices connected to your box except for pendrive used for flash.
ciao sono nuovo vorrei installare la chiavetta digtal key per vedere il dtt come si fa
1. You are in the INTERNATIONAL SECTION where only English is allowed
2. Take some time to search in the Board with Search function.
3. Say "Hello" in the "Introduce yourself" section.
