Black Hole Vu+ Duo 2.1.3
Dude you have bricked my box i install this with the usb it work after i will shutdown i press the black hole shutdown and it says your box is shutdown then i cant start any morr its just red ligt on the front box
Your box is genuine? I think NO. So no clones supported here.
Scusate ma questa immagine può essere installata su clarke tech et9000? se no qual'è l'ultima versione funzionante?
to begin with, you were the one that reflashed the box
so if anyone stuffed it, it would be you
no one forced you to do it
did you really expect to get any help phrasing a statement like that?
plenty of people flashed their boxes successfully with this firmware so before you start blaming these guys that work their arses of to make these firmware releases for no actual profit but are still happy to share it with you, have a bit of common sense!
more than likely there's a capacitor gone on your motherboard
I suggest you search the two keywords, there's plenty of info about it
for you it looks like it was just a coincidence that it happened after reflashing
but what i have to do now its just the red light is on USB NOT WOKRING NOT THE FAN i dont now how to fix it now maybe some IC CHIP OR somting has gone
anyone know why the screen shots on first page show the box booting with yellow screen where vu+ is mine still starts up in the blue colour can you change that
