Black Hole Vu+ Duo 2.1.4
Hi all thanks again for your hard work
I would like to ask a question I am having a lot of trouble with my Duo
I set up a swap file size of 512 MB on my USB stick ( 4GB Partitioned 1Gb Universe /3Gb media USB) swap file is set up as auto start straight away after I Flashed the box 2.1.4 (kernel V 3.9.6/ DVB drivers: 20141021).
but the box is running so slow and crashing a lot.
System info. Ram in Use 96% swap in use 0% Flash in use 97%
when i go into swap file (double blue button ) status Active
i hope you can put me straight where i went wrong confused so I am.
sorry I meant to state the above info was when I am in Black Hole
when i am in Avalon it reads Ram In Use 85% Swap in Use 0% Flash in Use 97%
and the swap file says its active in Avalon
I will stay in Avalon because less RAM but swap file still not working help
no i done everything in meoboot using swap file still keeps crashing
reverting back to Bh 2.1.3 looks like i am stuck there
Hello
I have a problem with the DVD player in 2.1.4 ? I can not use the yellow button and select subtitles ...
when I select the subtitles I want nothing happens ?
if I press the yellow button 2 times then I get the green screen (enigma2_crash) all the time ?
Is this the most current blackhole image for the VU+DUO original. or is there a better one now thanks
Black Hole 2.1.4
What is new in Black Hole 2.1.4:
All models: Full HD Skin ready.
The 1920x1080 framebuffer support recently introduced in Vu+ drivers has made it possible to use full hd skins. But many parts of the enigma2 gui are hardcoded with fixed fonts and itemheight.
This causes fonts at 1920x1080 resolution to appear far too small. All these gui parts have been re-coded in Bh 2.1.4 to support larger fonts and itemheight in case of full hd skins (thx to Matrix10)
Solo and Duo only:
The 1920x1080 framebuffer support has required extra Ram usage. For this reason the old Solo and Duo models do not have enough free ram to run the curent images with these new features.
In Black Hole 2.1.4 we have included ram compression (zram) that increases performance by avoiding paging to disk and using a compressed block device in RAM instead, inside which the paging takes place until it is necessary to use the swap space on a hard drive or usb stick. Since using ZRAM is an alternative way to provide swapping on RAM, zram allows Linux to make more use of RAM when swapping/paging is required.
misc:
  • drivers:
    201412005(zero, solose)
    - Improve PQ(zero)
    - Adjust LED brightness(solose, zero)
  • update driver
    20141201(solose)
    - Fix analog audio(solose)
  • drivers: 20141126(solose, zero)
    - Fix booting problem(solose)
    - Support LED brightness control in idle mode(solose)
    - Support LED brightness control in normal/idle(zero)
    - (Brightness can be controlled in Menu -> Setup -> System -> Display Setup)
  • New Skin MX-Black
  • Meoboot update: Fixed the issue of non working usb drivers in images in multiboot.
  • About screen: Add drivers version, kernel version and Cpu info.
  • Bh Full Backup update.
  • OpenWebInterface update.
  • WirelessLanSetup: add quote to wpa_passphrase for password.
  • Black Hole Swap panel: Allow to create swap files upto 2 GB.
  • Black Hole Swap panel: Update descriptions (Thx to Ev0).
  • Solo2: fix ethernet problem in some Gigabit switches.
  • Solo/Duo: implement Zram
  • Librtmp update.
  • Added to feed: livestreamer, livestreamersrv
  • Added to feed: python-mechanize python-futures python-pip python-requests python-singledispatch
  • [PATready] 'cnt' is increased twice, causing failure to obtain a single pmtpid.
  • [VirtualKeyboard] fix default layout (en) must be "qwerty"
  • Bh Device Panel: fix meoboot mointpoint only when meoboot is installed
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
hhhmm i have the 2.1.4 beta now for a time in my duo but the img keeps crashing
is it better for me to go back to 2.1.3 ??
i did everything to prevent it like making a swap file write everything to usb stick 8 gig
but even that does not do the trick
my question ...is there an other sollution??
thx
