Black Hole Vu+ Duo 2.1.6.1 Fast IPTV
Hi, I first have to apologise, I think I had this same problem before with a plugin on previous version and was suggested to me to try install one by one to see which casues BH to lock up. Anyway, sorry to same same problem again with my VU+Duo2, Installed 2.1.6.1 and have had same trouble but this time I have done what was suggested before and can identify problem plugin. I only install 5 plugins after an update, Autotimer, Seekbar, Permanent Timeshift , Merlin Program Guide & SerienFilm. Anyway, it's SerienFilm thats the Plugin that cause BlackHole to hang/stuck on the channel i was watching giving the symbol like a playing card in the top centre of the screen. This only happens when I try to access the recordings after installing this particular plugin. It's not a crash so I've no crash log. After installing SerienFilm, box acts normally but as mentioned once i press the button on remote for recordings it hangs and only way to get back control is to switch off at back of box. I hope this is helpful of interested if anyone else has same box s me and does not have this problem?
When I first installed 2.1.6.1, I installed all 5 at the same time, problem surfaced when accessing recordings. Then one by one, SerienFilm was the 5th of 5 I installed, each time checking if i could access recordings. Only after installing SerienFilm tid the problem occur.
I have now for the third time reinstalled 2.1.6.1 and the other 4 plugins without SerienFilm and all working fine.
When this happen to me before on the previous version I eventually downgraded to an older version to get my full five favourite plugins working without knowing which was the problem. Thanks for listening, love this new version of BH, keep up the good work. :-)
I installed BH and it run lovely for 3 days then picture blocked on tv, cannot use the remoot control anymore and have to restart my vu duo (original) from the back on/off plug
and it happen again and again. Any idea guys...?
Any idea why this image crashes with Mediaportal plugin? Works little while and then crashes and receiver reboots.After rebooting it crashes again with mediaportal and reboots.Older images had problems with mediaportal also.Receiver freezed in some point using mediaportal,but worked ok after switching power off from back.Anyone else have this "problem" or is that just me.Newest mediaportal installed.
Thanks, it has been a while since I download a new version, one question: to install plugins manually you had to move them to /var/volatile/tmp , now it seems that the location has changed, any help please?
